How do you change the time on a Yellowstone YS105 docking station?
Yellowstone radio ys105bl manual
how do I turn on a 2.1 docking system for ipod +iphone ys105bL yellowstonet that turned on then didn't
Feb 17, 2013 | Watches
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Jan 16, 2013 | Dell Inspiron 1545 Notebook
How to take Philips docking station out of military time into 12hr format
I think I already answered this but according to reviews I've read of this docking station it stays in military time only...but one reviewer did say that when you sync your phone with it that i will change the time on the docking station to what's on your phone.
Nov 04, 2012 | Cell Phones
HP Elitebook 8540p is getting no video in docking station
Try this
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=au&prodTypeId=321957&prodSeriesId=4097214&swItem=ob-83668-1&prodNameId=4096169&swEnvOID=1093&swLang=13&taskId=135&mode=4&idx=4
Jun 23, 2010 | HP EliteBook 6930p Notebook PC
MY D630 LAPTOP DOES NOT WORK IN DOCKING STATION
When powering on the D630 from the Docking Station, press F2 to go into Setup. Scroll down to the Docking Section, and check the Dock device info for the status. If it shows undocked, then try changing the below settings to: Hot Undock, Enabled Silent, and Universal Connect Enabled. Save these settings. Make sure you update your BIOS to A16 from http://support.dell.com under drivers and downloads section. If still not recognized after this, check the dock port on the D630 for obstructions or burn markings on the pins. try cleaning with rubbing alcohol and qtip swab. I have seen a few cases like this and ultimately the motherboard was the issue and needed to be replaced.
Dec 20, 2009 | Dell D/Dock Expansion Station Docking...
Docking station
typically if it's a complete docking station, it uses your laptop power supply and provides power to your laptop and itself at the same time.
http://www.dell.com/downloads/global/products/latit/en/laptop_latitude_efamily_docking_accessories_brochure.pdf'
according to that brochure the dock is the E series.. and doesnt come with a manual
Dec 11, 2009 | Dell D/Dock Expansion Station Docking...
Usb ports on the ibm docking station not active
Dear rajeshraja42,
Try to run the recovery CD from IBM Docking station, and reconfigure your system by connecting your docking station while you run them.
Or try this:
Connect your docking station to your Laptop then turn the Computer On!
Start>My Computer--- Then right click--- Choose 'Properties'>On the dialog box, ----choose the 'Hardware' Tab> Choose the Device Manager box by click them>Now You are in the DEVICE Manager Box>>>
Run the Scan For Hardware Changes... Then if you find that your docking station appear with Yellow Question Mark Then, right click on it and choose 'Uninstall' from context menu and answer YES! then Run the SCAN for hardware changes for ONE last time, Your System should find your Docking station as part of your system now!
GoodLuck!
Best Regards,
bionic23
Dec 07, 2009 | IBM (250410U) Docking Station for ThinkPad
Only noise from PC to monitor through docking station
I have the same problem and tried down loading the lates drivers without any change. It was working fine. I was in the middle of listening to music when it started.
Aug 22, 2009 | Toshiba Dynadock Port Replicator, Docking...
I have two docking stations for my Travelmate 8103WLMi both docking statins have lost there USB port connectivity. Is there anything that can be done so that the USB ports work again?
Try updating the drivers for the docking stations. Even in commonly used items such as docking stations which can be used without drivers, if you go to the manufacturer's web site and download drivers or management software, you will find it works better.
Otherwise, try somone else's laptop with those docking stations to make sure it's not your latop causing the problem. If it doesn't work for them either, the docking station is broken and there is really nothing you can do about that short of paying more than it's worth for someone to change out the USB component of the docking station.
Jul 09, 2008 | Acer Computers & Internet
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
