Question about Metropolitan Vacuum Metro Air Force Master Blaster Motorcycle Dryer, 8 PHP
Metro air force switch replacement - Metropolitan Vacuum Metro Air Force Master Blaster Motorcycle Dryer, 8 PHP
How do I repair Hoover Windtunnel floor/carpet switch? Brush will not turn but belt is not broken. I believe setting was hard floors and son forced the switch when the vaccuum was running.
The lever that switches from carpet to hard floors may be broken if it was forced, remove the cover to gain access. Replace both belts too. They may be stretched or worn even though they look good.
Dec 31, 2016 | Vacuums
Machine was running, it quit and has not ran since. This happened last week. I did change out the switch thinking that may be the problem.
Proteam Pro Force 1500XP Bagged Upright Vacuum
Tom, the motor has probably burnt out, if you dismantle machine you could test motor directly to prove faulty or just replace machine.
Mar 31, 2016 | Proteam Pro Force 1500XP Bagged Upright...
Rainbow E series vacuum shuts downs
When a bearing or the motor brushes go out it will cause the motor to shut down like this. If this is the case and you continue to try to force it there will be potential damage to the armature.
Jul 26, 2014 | Rainbow E series Canister Wet/Dry Vacuum
I broke the Air flow adjusting knob and can not get air to release on my Musting 255 can you help.
replace them you can get them from guarantee vacuum and sewing center
Mar 17, 2014 | Vacuums
Hi my hoover f7431900 brushes are not wrking is there any belts that needs to be replace.
No, there are no belts on this model. The brush moves by the force of air which is blown out by the turbine behind the brush. Generally, the turbine and maybe the gears need to be replaced.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie andie
Apr 15, 2011 | Hoover F7431-900 SteamVac Vacuum
WHEN I TURN OFF DYSON DC25 ANIMAL..GET A LOUD NOISE AS THE MOTOR IS SHUTTING DOWN....
I am experiencing the same problem with dyson 25 when the motor is shutting down - i hear a strange noise ....
Jan 05, 2011 | Vacuums
Hoover steam vac model f7425-900 filter is
The brush system on this model has a poor engineering design in that the brushes are running off an air turbine, which uses a steel bushing to spin the turbine which gets rusty from the moisture when the machine is being used. No long term solver. I would replace the machine with a Dirt Devil Platinum Force model
Nov 27, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Cuts out every 3 minutes
try the filter see if its blocked they have a thermal overload it will cut out if it gets too hot.
Oct 16, 2009 | Metrologic Instruments Metro Air Force...
Metropolitan Vacuum Metro Air Force Master Blaster Motorcycle Dryer, 8 PHP Logo
19 people viewed this question
Top Metropolitan Vacuum Vacuums Experts
Are you a Metropolitan Vacuum Vacuum Expert? Answer questions, earn points and help others
