Question about Danze Plumbing
Install danze kitchen faucet
I don't have instructions to install danze model d404554. Does anyone have instructions?
    New Friend:
Did u check there web site most have instruction manual if I could see it I could tell you more
Posted on May 09, 2014
  • 2712 Answers
SOURCE: kitchen faucet Installation
Many new faucets require some assembly before mounting to the sink; if that is the case, follow the manufacturer's directions. With most pullout sprayer faucets, the sprayer needs to be threaded through the faucet body first. Insert the rubber gasket between the base plate of the faucet and the sink top to create a watertight seal. If no gasket is provided, pack the cavity of the faucet with plumber's putty, then insert the faucet body through the holes in the sink top. Thread the mounting nuts provided onto the faucet shafts, then center the threaded shafts in the sink's holes and tighten the nuts firmly. Many manufacturers include a special long socket specifically to aid in tightening the mounting nuts. A hole in the socket accepts the shank of a screwdriver, guiding it as you tighten the nuts. If you're mounting the faucet on an installed sink, use this method. If you're installing a pullout sprayer faucet--or a faucet with a separate sprayer--now is the time to connect the sprayer to the faucet body. Check the manufacturer's directions to see if using pipe-wrap tape for this connection is recommended. Use an adjustable wrench to tighten the connection. Most pullout sprayer faucets and faucets with separate sprayers come with a counterweight that attaches to the sprayer hose. This weight helps retract the hose back in to the sink cabinet after you've used the sprayer. Follow the manufacturer's directions on where to secure the weight, and take care not to crimp the hose as you attach the weight. Hook up the faucet's hot and cold supply lines to the water supply shutoff valves under the sink. If necessary, gently bend the copper tubes coming out of the faucet for better access and connect flexible supply tubes to them. Simply wrap a couple of turns of pipe-wrap tape around the threaded nipples on the valves and connect the tubes. Tighten the nuts with an adjustable wrench.
Posted on Aug 27, 2008
  • 30 Answers
SOURCE: Looking for parts breakdown picture for DANZE NSF
NSF 61(-9) is a standard rather than the model number (it's often very difficult to identify the model number. If you are able to find the model number, the link attached has all the technical specs for Danze products (even discontinued ones). http://www.danze.com/tech_specs.asp
Otherwise, I suggest browsing their faucet section until you find yours.
Good luck.
Posted on Sep 18, 2009
  • 127 Answers
SOURCE: danze kitchen faucet spout difficult to move from
o-rings in the spout need to be greased or replaced...use silicon grease if you are greasing them....not petroleum based product.
Posted on Oct 18, 2009
SOURCE: REcently installed Danze Ashburyee kitchen faucet
Disassembled hose and realized all I needed to do was tighten the brass coupling to the hose. Problem is fixed.
Posted on Jan 31, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: faucet is leaking from the cold water line inside
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
Posted on Mar 30, 2010
How do i remove handle from danze kitchen faucet?
Google Danze kitchen faucet diagrams and it shows the intricate parts of different faucets
May 03, 2014 | Danze Plumbing
Danze kitchen faucet no:FS1B4034NP. It leaks around the spout when i turn the water on. I have received a new spout seal kit but no instructions on how to install
you should be able to unscrew collar,the top piece just before it goes into base,I use a piece of cardboard in the jaws of channel lock pliers to keep from tearing up chrome
Jan 28, 2011 | Danze Plumbing
I have a Danze Opulence kitchen faucet, i have replaced the aerator and cartridge, the faucet still drips,any ideas,thankyou.
below the cartridge should be some rubber washers if its the model im thinking of, try those. if not sounds like the whole valve needs to come out....
Jan 26, 2011 | Danze Plumbing
There's no set screw or plate covering the set screw. Not sure if handle just snaps on or what Danze Parma faucet
You didn't indicate exatcly what model. Check this link, and follow the install instructions. It tells you how to secure each type (3 different methods) One is a screw in the side with a cover over the screw.
http://www.danze.com/tech_specs.asp?show=D500058BN then click on install notes
Jul 04, 2010 | Danze & Single Handle Tub And Shower...
My danze kitchen faucet is loose and wobbly i cannot seem to tighten it i no longer have my installation insructions. please help. how do i do it?
You can see the installation manual here:
http://www.ajmadison.com/ajmadison/itemdocs/D403412-chrome_manual[1].pdf
Hope this helps! Remember to rate me, thanks.
May 26, 2010 | Danze D403412 Melrose Single Handle...
Looking for parts breakdown picture for DANZE NSF 61 Kitchen Faucet Any Links?
Good luck.
Sep 13, 2009 | Plumbing
I have a single handle kitchen faucet that now has no cold water
You need to install a new cartridge in the faucet.  The cartridge controls everything.
Mar 09, 2009 | Danze D403412 Melrose Single Handle...
Plumbing Logo
166 people viewed this question
Top Danze Plumbing Experts
john h
Andrew Bugbee
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
