Question about Motorola Mobility XT907 DROID RAZR M Verizon Unlocked Black
Phone in continuous Droid Eye loop won't go to start menu
  • Official Brand Answer
  • 1,623 Answers
CONTACT US for help.
Mark
Motorola Support
Posted on Jan 29, 2015
Does not start
You can try a reset to factory settings using the external keys. You can refer to the following link: DROID External key Reset Factory Data Reset.
Best Regards
Suny
Motorola Support
Mar 15, 2014 | Motorola Mobility Droid X (MB810) Verizon...
Tip
How To Reset Your Motorola Droid
<span style="font-weight: bold;">Soft Reset</span><br /> <ol> <li>Press "Control+Alt+Delete" on your Droid.</li> <li>The phone will reboot.<br /></li></ol><span style="font-weight: bold;">Hard Reset</span><br />This will clear all of the data off of the device.<br /> <ol> <li>Turn the Droid off. If it won't turn off, remove and reinstall the battery.</li> <li>Open the keyboard and press the <b>X</b> key while pressing and holding <b>Power</b>.</li> <li>The device will power on. Continue holding down the buttons until a yellow triangle "<span style="font-weight: bold;">Warning Sign</span>" appears on the screen.</li> <li>Once the yellow warning sign appears, press the physical "<span style="font-weight: bold;">Volume UP</span>" and "<span style="font-weight: bold;">Camera</span>" buttons simultaneously to get to the menu. This may take several attempts before success.</li> <li>Use the direction pad to the right of the keyboard to select the <b>Format</b><span style="font-weight: bold;"> </span>option, or the <span style="font-weight: bold;">Wipe Data/Factory Reset </span>option.</li> <li>Scroll down to the "<span style="font-weight: bold;">Yes -- delete all user data</span>" and press the "<span style="font-weight: bold;">Center</span>" button on the D-Pad.<br /></li></ol>
on Feb 15, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
My Droid x hd is frozen and I can't get a response
Remove the backing of the phone and pull out the battery. Then put the battery back in and turn on the phone. If remove the battery isnt an option,
1. Turn off phone
2. Press and hold Power key + Home hard key to power on the phone and bring up a triangle with an exclamation point inside next to a green Android graphic.
3. Press Search hard key (only froyo 2.2) to show the Android recovery menu. ( for firmware 2.3 Gingerbread Press both Volume buttons)
4. Tap to select "wipe data/factory reset" (you can also use Volume buttons to scroll up or down in this menu)
5. Press Menu hard key under "Ok" screen prompt (camera button can also be used to confirm selection)
6. Handset will ask you to "Confirm wipe of all user data"
7. Select "Yes -- delete all user data"
8. Press Menu hard key under "Ok" screen prompt to start wipeout of phone, handset will begin to format handset showing progress with multiple lines of ellipses (....) (camera button can also be used to confirm selection)
9. Handset may take from 5-20 minutes to format.
10. When format is complete, press Menu hard key under "Ok" screen (or use the camera button) when prompted to reboot (Reboot system now will be highlighted)
11. You will see either an open box and the green android graphic when handset is rebooting (or the red DROID eye graphic).
12. Handset will be cleared of previous personal data, and you will need to start over with initial set-up process.
Sadly thats the only process which includes wiping contacts etc. and last alternative.
Oct 20, 2013 | Cell Phones
Troubleshooting droid
1. Turn off phone
Htc incredible keeps saying droid and loop[ing from white htc screen to "droid" screen
Try to update to the latest android version. Your carrier might help you with this because it is so new. However if you dropped it (etc.) and your carrier doesn't replace it for you, You can get the part at Droid Repair and there is a guide that shows you how to put in the part at Droid Repair Guide.
Feb 16, 2011 | HTC Droid Incredible Cell Phone
My droid screen suddenly turned black but i could still use it, i tried resetting it by pulling the battery out but the same thing occurs. Whenever i would turn the droid back on, the Motorola symbol is no...
You might want to try a hard reset on the phone, it should put your phone back to normal if its a software issue, if its a hardware issue you might have to take the phone apart or send it in for repairs or warranty return.
You can hard reset your Motorola Droid if you want clear all of the data off of the device and start fresh. Here’s how it’s done.
1. Turn the Droid off. If it won’t turn off, take the battery out then place it back in.
2. Open the keyboard and press the X key while pressing and holding Power. The device will power on. Keep holding the buttons down until a yellow triangle appers.
3. Press the Camera and Volume Up buttons at the same time to get to the menu. (I had to press them several times).
4. Use the direction pad to the right of the keyboard to select the Format option.
Aug 16, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
My droid is on the pattern lock page (i do know what the pattern is) but it wont let me put the pattern in. I have removed the battery and powered the phone back on and the same thing happenes it is just...
You can hard reset your Motorola Droid phone if you want clear all of the data off of the device and start fresh. Here’s how it’s done.
Jun 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
My droid wont unlock
DO A HARD RESET ON IT
*Turn the Droid off. If it won’t turn off, take the battery out then place it back in.
*Open the keyboard and press the X key while pressing and holding Power. The device will power on. Keep holding the buttons down until a yellow triangle appears.
*Press the Camera and Volume Up buttons at the same time to get to the menu. (I had to press them several times).
*Use the direction pad to the right of the keyboard to select the Format option
www.usedcellphoneshop.com
May 24, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Motorola Mobility XT907 DROID RAZR M Verizon Unlocked Black Logo
48 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
