Question about Magellan GPS
Magellan miles to kilometer - Magellan GPS
Kilometers to miles
Multiply kilometers by .6 example '100 kilometers is 60 miles. I always figure so many kilometers and multiply by .6.
If you go 30 kilometers and want miles you figure 30 times .6 equals 18 miles.
Hope this helps.
Jul 02, 2017 | Cars & Trucks
How to go from miles to kilometres on my bmw 320d
A mile = 1.613 kilometers. To find kilometers, multiply the miles by 1.613.
A kilometer = .62 miles. To find the miles, multiply the kilometers by .62.
Dec 14, 2014 | BMW Cars & Trucks
What is the speed of an automobile in kilometers per hour if it is trveling 45 miles per hour?
There are 1.609344 kilometers in 1 mile. So you can just put it this way.
45 miles x 1.609344 kilometers
1 mile
The answer is 72.42048 km or just 72.42 kilometers
Therefore the automobile is traveling 72.42 kilometers per hour.
Hope this helps.
Jun 27, 2011 | Casio FX-9860G Graphic Calculator
How do I change from miles to kilometer on1470 model
On page 30 and 31 of the Uses Manual
Selecting Units of Measure
Auto power is the duration of time that the Magellan RoadMate receiver remains idle before turning off
automatically.
1. Access the System Settings menu (above).
2. Tap Units.
3. Tap on the desired unit of measure.
4. Tap the back arrow .
http://support.magellangps.com/support/assets/manuals/MagellanRoadMate1470_UserManual.pdf
Jun 26, 2011 | Magellan RoadMate 1470 GPS Receiver
Purchased focus sport 2006 model no service manual. Mileage 43,000 kms. Need to know service intervals either time/mileage perhaps a copy of the service schedule will suffice.
These maintenance intervals come from the maintenance interval calculator
at www.autozone.com, using a starting point of 25,800 miles (43000 km), and
assuming 1000 miles (1666 km) driven per month, and "severe driving conditions," which
are actually normal usage characteristics, such as frequent short trips, urban driving, waiting in traffic, driving in hot weather, trips under 16 km in cold weather, etc.
STARTING MILEAGE: 25800 (43,000 Kilometers)
Item
Action
Service History
20000 miles or 32000 kilometers
Battery Check
Oil Filter, Engine Replace
Engine Oil Replace
Vehicle Inspect
Brakes and Traction Control Inspect
Tires Rotate
21000 miles or 33600 kilometers
Steering and Suspension Lubricate
Engine Oil Replace
24000 miles or 38400 kilometers
Engine Oil Replace
25000 miles or 40000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
27000 miles or 43200 kilometers
Engine Oil Replace
30000 miles or 48000 kilometers
Battery Check
Air Filter Element Check
Wheel Bearing Lubricate
Fuel Filter Replace
Engine Oil Replace
Fluid - A/T Replace
Cabin Air Filter Replace
Vehicle Inspect
Cooling System Inspect
Wheel Bearing Inspect
Ball Joint Inspect
Drive/Propeller Shaft Inspect
Exhaust System Inspect
Steering and Suspension Inspect
Heat Shield, Exhaust Inspect
Tires Rotate
33000 miles or 52800 kilometers
Engine Oil Replace
35000 miles or 56000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
36000 miles or 57600 kilometers
Engine Oil Replace
39000 miles or 62400 kilometers
Engine Oil Replace
40000 miles or 64000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
42000 miles or 67200 kilometers
Engine Oil Replace
45000 miles or 72000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
48000 miles or 76800 kilometers
Engine Oil Replace
50000 miles or 80000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
51000 miles or 81600 kilometers
Engine Oil Replace
54000 miles or 86400 kilometers
Engine Oil Replace
55000 miles or 88000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
57000 miles or 91200 kilometers
Engine Oil Replace
60000 miles or 96000 kilometers
Battery Check
Fuel Filter Replace
Spark Plug Replace
Fluid Filter - A/T Replace
Engine Oil Replace
Fluid - A/T Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
63000 miles or 100800 kilometers
Engine Oil Replace
65000 miles or 104000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
66000 miles or 105600 kilometers
Engine Oil Replace
69000 miles or 110400 kilometers
Engine Oil Replace
70000 miles or 112000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
72000 miles or 115200 kilometers
Engine Oil Replace
75000 miles or 120000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
78000 miles or 124800 kilometers
Engine Oil Replace
80000 miles or 128000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
And you can continue the pattern from there...
May 14, 2011 | Ford Focus Cars & Trucks
2005 cts @ 100,000 what service needs to be done?
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - EXHAUST SYSTEM - INSPECT
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - FUEL SYSTEM - INSPECT
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - AIR CLEANER/ELEMENT - REPLACE
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - FUEL FILTER - REPLACE
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - SPARK PLUGS - REPLACE
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - TIRES - ROTATE - [Tires should be rotated every 5000 to 8000 miles, and/or at maintenance I or II service intervals.Check tire pressure, thread depth and wear.]
Feb 07, 2011 | 2005 Cadillac CTS
Tomtom xl340 how do i change from miles to kilometers
Under Change Preferences:
First, Show ALL Menu Options.
Then, select Set Units.
Miles/Kilometers will be the first choice you'll be asked to make.
Dec 23, 2009 | Tomtom Go 630 GPS Receiver
Ow do you changes from kilometers to miles and where do I get an operator's manual in English?
To change kilometers to miles, divide the number of kilometers by 1.609. To change miles into kilometers, multiply the number of miles by 1.609.
For mavic manuals, go to http://www.tech-mavic.com after you check out this link from Serotta:
http://www.serotta.com/forum/printthread.php?t=6572
May 08, 2009 | Mavic Ksyrium Elite Wheelset
How can i solve this problem?
/* REXX is better than JAVA -- see: http://www.REXXLA.org */
say 'Welcome to the class named DISTANCE'
pull kilometers junk
if kilometers = ' ' then exit
conversion = 0.62137
miles = kilometers * conversion
say kilometers 'Kilometers is' miles 'Miles.'
exit
Aug 10, 2008 | Computers & Internet
GPS Logo
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
