Question about Hitachi 57SWX20B 57" Rear Projection Television
Hitachi 51GWX20B Rear projection HD tv, convergenance/color issue
I am just getting beat up by this TV. I was having issues similar to what i was reading on here. I replaced BOTH conv. chips ith the STK392-150 'upgrade'. Now i have a whole new set of headaches:
1. After about 1/2 hour the screen starts to shrink and cutoff about 4 inches or so of the left screen while keeping everything else in ratio...pretty strange and really similar of the orignal problem which led me to replace the convergance chips in the first place.
2. The blue is WAY!!!! off...inches. Far past repairing with a manual magic focus.
3. I have toy'd a little and learned how to trigger the alignment screen with the small button on the convergence chip board (next to the v and h size) I have been unable to find any other pot's for adjusting that blue. The other two colors are right on. The blue is pinched in the center. Its close in the center but far off on the outside edges, arching in to the center.
4. I assume due to the size of the heatsinks on the convergence chips that they are meant to heat up, but they get really hot. I either have an issue or wonder why hitachi didn't put a small fan in the unit.-any help with be appreciated as im pretty dead in the water.
  • 668 Answers
I bet you have a open resistor for the blue sub yoke. Typically it would be a 2.2 omh or a 1.5 ohm. Some times it is hard to tell buy looking at them. It you have a Ohm Meter, unplug the set, pull the sub yoke plugs from there connectors.(They are the plugs right behind the heat-sinks) . If you know the resister color code it will be a must to determin if any are open or increased in value. If you see a resister that has two red bands and two gold bands, it it a 2.2 ohm. A resister with a brown band, green band, and two gold bands is a 1.5 ohm. On some occasions, you will see a brown band, a white band and two gold bands, this is a 1.8 ohm. This circuit does not give much leeway for subing with wrong values and it even could cause premature failure if the IC's again. One last thing, double check that all the pins made it through the board when mounting and are not touching each other top side of board. As far as the one side of the picture pulling in , I think it is all related. I have seen defective STK392-150's new out of the bag.
Well thats all I can tell you at this point.
Good Luck,
Skyassoc
Posted on Jun 19, 2009
Have convergence issues using dish satellite " the hopper" but not when watching blu ray DVDs
Convergene issue on RCA projection TV sets are fairly common and usualy easy to fix. You can get the parts or complete kits from sites such as Tv Repair Kits.
Apr 03, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
I'm getting an overlapping of two colors on the screen.
It is common problem with rear projection tv and 3D type picture problem occurs due to failure of convergence output ICs, replacement of convergence output ICs will fix the issue and tv will again show correct converge picture as before.
Let me know tv model number written on back of tv if you want to fix tv by yourself as it needs soldering parts in circuit board expertise and if you feel uncomfortable working in tv circuit boards than local tv repairman will do this job for you.
Thanks.
Jun 30, 2010 | Hitachi 61SWX01W 61" Rear Projection...
My TV shuts off seconds after turning it on. I hear clicks and shuts off. Please help. Hitachi 43fdx15B rear projection tv.
I have a very similar issue. Problem seems to go away after the TV has been on a bit and warms up. Did you find a solution for this? Thanks.
Oct 30, 2009 | Hitachi 65SWX20B 65" Rear Projection...
Rear projection HD Hitachi Ultravision always has greenish tint
This is what you're going to do, Turn on the Tv and go to the service manual, if the green tint is still there, you have a defective dmd board, but if it's no there, then you have an issue with your video board
Jul 09, 2009 | Hitachi Televison & Video
LCD rear projection tv has green and yellow discoloration at the top and bottom of the screens
This sound like a Bad Optical Block. If this is a Hitachi, and it is less than 3yrs old, I would try to see if Hitachi will help with the repairs. You would still need to get a local authorized repais facility out to comfirm it is the Opical Block. They should be able to help with that as well.
Hope this helps,
Skyassoc
Jun 29, 2009 | Hitachi 51GWX20B 51" Rear Projection...
Double image
Problem seems in convergence out section.
TV needs Convergence Out ICs replacement.
If you have TV repair experience and know good soldering work then you can give it try OR get help of qualified TV tech to fix it.
If you need further help, let me know.
Dec 30, 2008 | Hitachi 51GWX20B 51" Rear Projection...
51GWX20B Getting very dim
Bad capacitors in power supply circuit.47uf 250v
Mar 09, 2008 | Hitachi 51GWX20B 51" Rear Projection...
Hitachi 51GWX Scrambled Picture
STK392-560 STKS convergence CHIPs Replace both of them.
Feb 24, 2008 | Hitachi 51GWX20B 51" Rear Projection...
HITACHI ultrascan hd tv....
toni, you`ll need a tv tech for this problem, spark gaps need to be cleaned, crt sockets need to be cleaned and crt pins on all 3 crt`s need to be sanded, this is a common issue with this model set, good luck, BMW Rider
Dec 17, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi projection tv model 3 51gwx208
Do you mean that at the top of the picture, the red color has shifted downward, bowed towards the center? If that is what you see, one color suddenly bows toward the center on any side of the picture, then it means that one of your convergence IC's has burned out and needs to be replaced. It is a good idea to go ahead and replace both STK392-110 IC's with the newer improved STK392-150's. If you have never replaced convergence IC's and realigned the convergence circuits in a projection TV then allow a qualified tech to handle it for you.
Aug 05, 2007 | Hitachi 51GWX20B 51" Rear Projection...
Hitachi 57SWX20B 57" Rear Projection Television Logo
355 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
