Question about HID Corporation EntryProx 4045
Factory default entryprox
Want to factory default unit
Dvr ja7204
Restoring Default Settings
To restore factory default settings to your DVR:
1. Enter the Factory Default menu, by going to Main Menu > Maintenance > Factory Default.
2. Select the OK button to restore factory defaults or select the Cancel button to return to the previous menu.
Note: Network information such as IP address, subnet mask and gateway will not be restored.
hope thid helps. and you can also try removing all power from unit if it does not have inturnal battery. if it does have an internal battery after removing all external power you will have to remove battery to completely reset. Note the latter suggestion will void warrenty if you have to open the unit to remove the battery.
GOOD LUCK :-)
Jun 14, 2014 | Computers & Internet
DVR-7318V Factory Default Settings
Look at the unit, you will be looking for a small hole in the unit. You might get lucky and it will say reset. If not the hole will be about the size of a paperclip end, and that's also the tool you will need. Push the button in the hole and HOLD it for a slow count of 30 seconds. Release it and let the unit go through it's startup . This should reset it back to factory default.
Feb 22, 2014 | Computers & Internet
Manual download
want to reset password
Sep 26, 2013 | HID Corporation EntryProx 4045
4045 GATE ACTUATOR
You can see it in the EntryProx 4045 Manual on page 23. It shows the wiring diagram for the unit.
Feb 02, 2013 | HID Corporation EntryProx 4045
How do I factory reset my Acer N270?
Hello
1. Restore your unit back to factory default via boot up on the ACER screen, hold down ALT and tap F10.
2. Select "Restore system to factory default".
3. Enter your Empowering Technology password and away you go.
If that doesn't work, your unit was shipped with recovery cd's
Hope this helps
Feb 01, 2011 | Acer Aspire One AOA110-1113 Netbook
A few months ago someone was getting into my router & downloading movies, I assume. Had a tech help me put in a password to secure it. Forgot the password & now can't use my ipod touch at home. Any...
Yes there is.. BUT you'll have to set up the security again... Fortunately DLink has a handy setup wizard which you can access here.. http://support.dlink.com/emulators/di514_revc/h_wizard.html
This will work right on your browser. You might want to test that it works on your system before wiping the router. (Just start it up then cancel if it starts)
Find the recessed reset button on back of the router close to the power input. Press and hold it with paper clip or pen tip for 10 - 15 seconds. This will restore it to factory settings.
You should use a wired connection to access the internet after that, no password. Go to the link above and use the online wizard to setup the router with encrytion and new password.
If it all orks wout for you kindly give me a rating. Thanks.
Jan 29, 2011 | D-Link DI 514 Wireless Router (DI-514)
Restore to factory default
Most Acer M1640's can be restored to factory settings using the following method:
1. Start with the computer off.
2. Power on the unit, this should cause the Acer POST screen to appear.
3. During the Acer POST screen, press and hold the Alt key on your keyboard, and tap the F10 key on your keyboard.
4.If timed correctly, this should cause the unit to go to a black screen that says "Windows is loading files...".
5. After the "Windows is loading files" screen you should be in Acer e-recovery management. At this point follow the on-screen instructions to restore the unit to factory defaults.
Oct 08, 2009 | Acer Aspire M1640 Refurbished Intel...
Need factory default for a garmin streetpilot c550 gps or pin unlock code?
There is no factory default unlock PIN code. You will need to take the unit back to your security location and it will automatically unlock.
May 18, 2009 | Garmin StreetPilot C550 GPS
Forgot username n password
you will need to reset the unit by depressing the reset button with a pen on the back of the unit.
Jan 26, 2008 | D-Link 802.11g Wireless Router WBR-1310...
HID Corporation EntryProx 4045 Logo
83 people viewed this question
Top HID Corporation Home Security Experts
Lawrence Oravetz
Are you a HID Corporation Home Security Expert? Answer questions, earn points and help others
