Question about Poulan Garden
Where does the fuel line with filter go on the carb?
The fuel line on my leaf blower broke into pieces. Ineed to know
where does the fuel line with filter go on the carb of the leaf blower?
Where does the other fuel line go?
  • Anonymous Mar 17, 2014
    Where can I get spare parts for thisthe BL 150 leaf bloer I nedd the fuel primer and lines going into the tank?
  • 1,041 Answers
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jun 20, 2009
  • Jim Parker
    Jim Parker Jun 21, 2009
    Thanks for the rating!
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
Broke small black connector between fuel line to side of carburetor. Flat bottomed funnel shape fits in to side of carb. Has filter inside. I believe it feeds the primer.
That is a fuel tank vent kit. Most models have a vent in the fuel cap but that model uses a separate line with a Duck bill vent (usually a green rubber inside that piece in picture). Part number for that is 574859301 . Your blower should run ok with out it but could leak fuel. If you are going to order any parts for your blower do so using Model # PPBP30 Your parts will be cheaper. That particular model has exchanged hands between MTD/Mcculloch/Bolens and Husqvarna/Poulan over the years. The parts are cheaper when you use the Husqvarna/Poulan model # PPBP30. Only noticeable difference will be a yellow starter housing if you buy a starter assembly.
Dec 17, 2015 | McCulloch ASB3206 - Blowers - 30cc Gas...
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
Husqvarna 125b stalls at high rev.
The fuel hose just throught the grommet comes from the pressure side of the primer bulb, it does not have to be very deep into the tank, it is just the return to tank hose, the hose kit withe grommet and filter is part no. 545081841
Jan 13, 2013 | Husqvarna 125b Hand Held Leaf Blower
Poulan Pro leaf blower does not get fuel to the carburator. It isn't very old. The filter was off and on the bottom of the fuel tank. I replaced the fuel ines. I have switched the lines and tried
If the fuel filter has fallen off the fuel hose, then the internal carb screen will be blocked, you need the remove the carb, remove the cover on the carb held with a single central screw ( pump side ) here you will find the screen ( fine filter ) clean or replace this, if you can acsess the cover without removing the carb all the better.
Dec 26, 2012 | Poulan Garden
Does the 4cycle backpack blower have a filter on the carb ? if so where can i buy one ?
There is a screen inside the card to keep out the big stuff.
There may not be enough room to install a filter.
See a motorcycle shop with a piece of the fuel line in hand.
Nov 12, 2012 | Troy-Bilt 32cc 4Cycle Backpack Blower
Ineed to remove the gastank on a ryobi back pack blower
The line is replaceable without removing the tank
Oct 24, 2012 | Garden
MY MACHINE IDLES BUT WILL NOT REV UP. I HAVE FITTED A NEW CARB REBUILD KIT
Check the fuel filter on the fuel line in the tank and ensure it isn't blocked.The fuel line can be pulled out of the tank with a piece of bent wire.Check there are no kinks in fuel line.
Make sure that the air filter isn't blocked.
Check the throttle cable is operating the throttle plate in the carburettor ok.
Mar 11, 2011 | Ryobi Backpack Blower 25.4cc
2006 25cc 2 cycle craftsman leaf blower
The smaller line that has the fuel filer on it in the tank goes to the stem on the lower part. The larger line that just terminates shortly inside tank goes to the stem on the top of the carb with the bulb.
Nov 30, 2009 | Craftsman Garden
The fuel line broke and I noticed one only one connection from the carb and two from the fuel tank. I hooked one up and primed it and it ran. What about the other one coming out of the fuel tank? Thanks
One line is hooked to the fuel filter in the tank. It feeds fuel to the carburetor. The other line is a return line from the carburetor. The return connection of the carburetor is on the back side toward the impeller housing.
Good Day.
Oct 05, 2009 | Homelite 'Yard Broom' Leaf Blower
On weedeater blower and vac gas line is broke from carb into tank does it just connect to fuel filter in tank model 1925
Yes if your asking about the fuel line yes it hooks to the filter out thru the wall of the gas tank straight into the carb. if it broke out side the tank you can try a smaller plastic hose to stick inside to reconnect the two parts. if it broke inside the tank try to replace as one hose.
Jul 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
560 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
