Question about Pride Celebrity Xl 4 Wheel Scooter
Tyre pressure What pressure?
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
You should find it marked on the wheel and or around a tyre valve. If you have standard tyres and tubes check your not very useful Pride instruction book.
Posted on Aug 02, 2016
Tyre pressure for tyre size 5.00 - 10
The maximum pressure will depend on the ply rating of the tyre and the working pressure will depend on the application.
A 4 ply tyre has a maximum pressure of around 32 psi and an 8 ply tyre about 65 psi. For many years this essential safety information has been moulded into the sidewalls.
Sep 22, 2017 | Cars & Trucks
What are the tyre pressures for a peugeot 208
the tires have that stamped into the side walls . and should also be on the tag on the door frame .
Nov 18, 2016 | Peugeot Cars & Trucks
What's the tyre pressure for a caravan with 185r14c on it
It depends upon the type of tyre, whether you have a single or dual axle as well as the weight of the van when loaded.
The maximum tyre pressure for the type of tyre you have will be listed on the sidewall of the tyre. Given the weight of a loaded caravan I would recommend you run the tyres at 2 PSI under the maximum pressure listed on the tyre for a cold inflation. If the maximum is, say, 40 psi then run the tyre at 38 psi. Tyre pressures will increase when the tyres are warmed up from running so always check and adjust the pressures when cold and purchase a good tyre gauge to carry with you if you do not have one yet. Higher tyre pressures within max specification, will lower the tyre's rolling resistance and tyre heat build up, places less stress on the tow vehicle and will give better tyre life on the van tyres.
Tyres are maximum load rated so know the van weight and make sure you do not exceed the load limits of the tyres (printed on the side wall) when adding weight to the van, including water storage.
Tyre Sidewall Explained
Jun 06, 2016 | Cars & Trucks
Im looking for a tyre pressure sensor for my renault laguna 2033 plate but not sure what im looking for or how to fit one thank you
1. The tyre has to be removed to fit the tyre valve/ sensor unit to the wheel. . Tyre dealers will do this for you when you supply the sensor.
2. Any renault dealer parts department can sell you a new sensor.
3. The new sensor has to be programmed to the car's tyre pressure monitoring system (TPMS).
3. Here is a list of information about the Renault Laguna tyre pressure sensors to assist you. The 2nd link below shows a picture of the tyre valve/sensor unit that fits to your wheel.
http://www.petercoopercarrepairs.co.uk/renault_laguna_mkii.htm
Renault Laguna Megane Tyre Pressure Sensor World Car Parts Store
Jan 07, 2016 | Renault Cars & Trucks
Tyre Pressure for Majestic 19.6 ft Caravan
Depends also on the kind of tyre.
For the maximum load of tyre nex kinds need next pressure , wich is called AT-pressure/maxloadpressure/reference-pressure , for up to maximum speed of tyre or if lower 160km/99m/h. This is not the maximum pressure of tyre.
Normal car tyre /standardload AT 2.5bar/36psi ( exeptions as low as 2.2)
XL/Reinforced/Extraload AT 2.9bar/42psi ( exeptions 2.8 and 3.0)
6PR( plyrating) /C-load AT 3.8bar/55psi EUR ( USA 50psi/3.4bar)
8PR/D-load AT 4.5/4.8 bar/ 65/69/70 psi
From E -load is not often used in Europe.
From this AT pressure you can calculate the needed pressure for lower loads . Made spreadsheet for it in wich I first add 10% to the assumed load before calculating.
Will give example picture
Jan 06, 2015 | Cars & Trucks
What tyre pressure should the 2002 polo 1.4 auto be? Type of tyre: 165/70R14 Thanks a million.
2002 VW Polo 1.4
Tyre: 165/70 R14
- Front tyre pressure: 2,2 ... 2,4 bar
- Rear tyre pressure: 2,0 ... 2,6 bar
- Spare tyre pressure: 4,2 bar
Aug 22, 2011 | Volkswagen Polo Cars & Trucks
I want to know the tyre pressure front and rear daytona 1200
Yup nice question. For any vehicle accurate tyre pressure will give you better tyre life, low running cost, etc. Here is a chart for car tyres click here.
For bikes i havent found any chart. basically in india rear tyres having 100/90 18inch maximum tyre pressure is 32psi. front tyre having 2.75P or 80/90 18 inch uses 24 psi pressure. and do check your tyre pressure twice a month.
Dec 12, 2009 | 1995 Triumph Daytona 1200
Correct tyre pressure hyundai accent coupe i
DEPENDING ON TYPE OF TYRES IT SHOULD BE 2.2BAR LOOK ON THE TYRE PRESSURE IS PRINTED ON THE TYRE
Jun 30, 2009 | Hyundai Motor 1998 Accent
Tyre pressure
it doesn't look like the tyre is low. When I got to work and had a look the tyre seems a bit soft if you push and pull the tyre as if to check the wheel bearings the tyre seems to wobble on the rim. So I'm wondering if the pressure is right what is the norm tyre pressure on the back?,Id run that tyre 28-30 if it was on mine,,,
Nov 10, 2008 | 2005 Hartford VR 200H
Tyre pressure
Nov 10, 2008 | 2007 CCM 404 DS Trail
Pride Celebrity Xl 4 Wheel Scooter Logo
50 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
