Saving SLides to SD Card using OTEK FS-35 IV Scanner
Not able to save slides to SD Card from scanner
Davroslives
  • 29 Answers
SOURCE: Scanning slides with the Epson Perfection 1250
To be honest, I have no idea of how you were able to scan larger transparencies in the past. The scanner and its software were never designed to do this and there is no workaround.
Posted on Sep 10, 2007
bluegreenash
  • 661 Answers
SOURCE: Scanning slides with anoscan 4200F
have you tried checking for a firmware update from the manufacturer?
Posted on Oct 13, 2007
  • 14 Answers
SOURCE: Minolta DiMage Scan Dual IV
1) Install all of the usual Minolta software in Vista.
2) Create a new folder somewhere
3) Create a new txt file named minolta.inf and paste this into it:
; scanners.inf -- Test Vista Minolta Film Drivers
; To remove this driver and install the original
; manufacturer's driver, go into Device Manager,
; open Imaging devices, then click on the scanner name
; with the right mouse button and choose Uninstall.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=3/12/2009,2.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB scanners
"Minolta Scan Dual II" = USBScanner,USB\Vid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USB\Vid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USB\Vid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USB\Vid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USB\Vid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USB\Vid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USB\Vid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USB\Vid_0638&Pid_0a16
;---------------- Duplicated from [Models]
[Models.ntamd64]
; USB scanners
;---------------- USBScanner -------------------------
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[Strings]
Provider="Konica Minolta"
Mfg="Konica Minolta"
4. Save file. Turn on scanner and go into device manager and update the old minolta driver with this driver. You may have to manually update it.
5. All the normal Minolta programs now work just fine. Enjoy!
Posted on Mar 12, 2009
SOURCE: CANOSCAN 8400F 35mm SLIDES PROBLEM
Please see my other postings (wireguy) regarding this same problem. It's caused by a faulty FAU cable.
Posted on Mar 28, 2009
SOURCE: Cannon 4400F Scanner
I had the same problem with about 1 out of every 16 slides when I first got the scanner. The only way I found around it was to rearrange the slides and try again. I started scanning through the ScanGear software instead of Canon Toolbox, and haven't had that problem since. I've scanned about 6,000 slides and negatives so far.
Posted on Apr 06, 2009
Poor quality conversion from slides to digital
Specify the format : .JPG or whatever it is.. please try to be specific.. SD Card is not a format.. its a storage media..slides as well is not a format.. its a terms..
Dec 19, 2013 | Wolverine Data F2D200 Film Scanner (35 mm)
Tip
Nikon Coolscan IV ED Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan IV ED?
Try this solution:
Take a AAA battery and place it in rear, left side of the slide feeding tray as pictured below:
The slides will fan out nicely, and your Nikon CoolScan IV ED will no longer try to load more than one at a time. Instead it will load them one at a time, 50 per tray, and you can actually walk away from it and let it do its job, just the way you intended to when you bought the SF-210 slide feeder attachment!
I hope that helps.
on Apr 09, 2010 | Nikon Coolscan IV ED Film Scanner
Bad quality slide conversion to digital
I think probably your data was not properly transferred/converted or the SD card was unmounted when the data was not completed transferred.. Hope it helps.. :)
NEED HELP WITH OTEK SCANNER PS979 MANUAL
I received one of these for Christmas and used it today for the first time. I have used it for slides and negetives but the photos don't illuminate uniformly as they have a bright strip in the middle.
As far as the manual goes, it is very poor. Also the controls and sequences are not very intuitive.
While it has a USB connection it seems to only use it for power. (my Windows 7 machine does not recognize it). As luck would have it, I had a spare SD Card and it works well but it would have been much easier (for the user) to have it saved on the computer directly but I suspect some of the functions built in may make this difficult especially with competing operating systems.
You have to save to the SD card and then transfer the card to a card reader to get it into the Computer for any fancy editing.
Best of luck.
Please let me know if Photos are illuminated uniformly.
James P
Dec 27, 2012 | Office Equipment & Supplies
Does the HP photosmart 2710 scan negative ansd 35mm slides?
This multi function printer/scanner cannot scan 35mm slides and negatives.
Some flat bed scanners with a lighr scource that shines through 35 mm slides and negatives can scan them.
You will be better off getting a dedicated 35 mm slide/negative scanner.
Check out this WEB site foe slide scanners.
http://www.google.com.au/#q=35mm+slide+scanner&hl=en&prmd=imvns&source=univ&tbm=shop&tbo=u&sa=X&ei=dYFIUPKBKMSyiQedl4G4DQ&ved=0CEkQrQQ&bav=on.2,or.r_gc.r_pw.r_qf.&fp=4469b7ccc4340a33&biw=1016&bih=535
Sep 05, 2012 | Epson Office Equipment & Supplies
How can I use my HP6210 officejet scanner to scan 35 mm slides
You cannot scan slides with this scanner.
Slide scanners need a light source that shines through the slide not a reflecting light like your scanner.
Jul 11, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Help! We opened the box for our new Brookstone Slide and Negative Scanner Model # SKU634402 and the installation CD was missing. Is there online installation available or should we just return the item...
A search for that model on Brookstone's website takes me to the iConvert Instant Slide and Negative Scanner. That scanner does not require an installation CD. It works by scanning slides or negatives and then saving them to an SD card. Many digital cameras use SD cards so you may have one already. Otherwise an SD card will need to be purchased separately.
Feb 28, 2011 | Brookstone Cameras
Jan 25, 2009 | Canon CanoScan 4400F Flatbed Scanner
Scanning 35mm slides and saving to computer
In order to scan 35mm slides to your computer, you need a scanner that has the capability of doing this. These scanners will either come with a 35mm adapter that will allow you to scan the slides, or there are scanners that will scan only 35mm slides. A good recommendation is either this or this.
Thanks and please take a moment to rate as fixya.
Nov 24, 2008 | Canon Office Equipment & Supplies
Scans slides too dark.
maybe the slides are too dark, in other words, the pictures you took didn't have enough exposure therefore you it shows up dark.. You could always use photoshop or someother photo manipulation software to lighten the scan, same thing happens with my hp scanner with slide adapter, if it slides just show up dark, lightening it with software will help, unless it is unsaturated/shadows too dark, etc..
Hope this helps.
Nov 11, 2008 | Konica Minolta Dimage Scan Dual IV Film...
65 people viewed this question
jasbo
jasbo
