Question about Crafts & Hobbies
Pebblecrete yourself instructions - Crafts & Hobbies
Can you forward the instructions to me
I can't forward any "instructions" because you never specified FOR WHAT.
In any case, you can find these instructions, if available, doing a GOOGLE search yourself for terms
Instructions o Manual, your unspecifed "phone" indicating the make and model
Sep 23, 2015 | Lands Phones
Laptop won't charge
It may be your laptop dc power jack is loose or dead. You should fix it. If you are good at tech, you can do it by yourself based on the following instructions:
http://www.chargerbuy.com/blog/dc-power-jack-repair-guide-do-it-yourself-instructions/
Otherwise you need to take it to a tech center for examination. Hope this will help you
Jan 20, 2013 | Dell Inspiron 1018 Notebook
Loose ac adapter plug
For this issue, you may take it to repair or replace your laptop dc jack. If you are good at tech, you may fix it by yourself on the basis of the following instructions:
Dec 27, 2012 | Lifetime Toshiba Satellite L505S5971...
Replace ac power socket in laptop
Hi if you specialize in repairing computer, you can repair this ac power port by yourself on the basis of the following instructions:
Oct 31, 2012 | Toshiba Computers & Internet
My charger port is starting to not work
Obviously, your laptop dc jack is loose. You should repair it or replace it. If you are good at repairing computer, you can follow up the following instructions to do it by yourself:
Oct 25, 2012 | Computers & Internet
Hinge shimming instructions H 1399 Where can I find these instructions? Installed prehung door doesn't close tight. Where to place shim under hinges? This is a do-it-yourself project.
http://www.stanleycommercialhardware.com/pdf/shimming_inst.pdf is a link to the H1399 document by Stanley Hardware entitled "Shimming Instructions"
Jun 09, 2011 | Crafts & Hobbies
Lost instructions. need to know how to set timer
We are always ready to help the do-it-yourselfer.
Please add a comment and describe your timer in detail, and I will check my files for instructions to match.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 01, 2011 | Hardware & Accessories
How often should I need a new thermostat. I change it three yrs ago and now the problem is occuring again. Are they trying to rob me?
I doubt it,but you can change it yourself. Often we recommend thermostat as a first step because it's cheap. You can do it yourself for a few bucks.
Please see my tip at http://www.fixya.com/cars/r5929960-s_thermostat . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Oct 20, 2010 | 1998 Jeep Cherokee
Alarm goes off whenever a button is touched
I have read the instructions for your watch and the feature you describe does not seem to appear on the description. Which makes me think the watch may be faulty. I suggest you check this conclusion yourself by reading the instructions, if you agree with me, then take it back to a dealer.
You can read the instructions for yourself by going to their web site "freestyleusa.com", select "support" and then "instructions".
(Some watches have a "beep" mode which operates in the manner you descibe, but it does not appear to be a feature of your watch.)
Jan 14, 2010 | Freestyle Convert Watches: Convert Black...
Hello i have a hd50lpw62ayx2 and the color wheel is bad would i be able to fix this myself??
yes you can do this yourself you can get a color wheel at the sight I posted also installation instructions as well as indexing instructions as well as free online tech support while you are doing the actual install incase you need help. By doing this yourself you will save approx 400.00 on labor alone
http://servicemanuals.vstore.ca/
Apr 25, 2008 | Televison & Video
Crafts & Hobbies Logo
73 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
