Question about Caterpillar 3406 Engine
Jacobs engine brake dont work - Caterpillar 3406 Engine
Have 1995 peterbilt 3406c cat engine, when I turn on jake brake some times it works some times not.when on it kicks outand back on when it wants what can cause this
the wires for the jacob brake are in the engine oil and are subject to heat and failure
It indicates that the circuit is failing so take it to cummins for a check and diagnosis of the jacob brake system
Feb 03, 2017 | Cars & Trucks
How does my engine brake work?
Engine brakes or Jacobs brake on diesel engines work by using engine oil pressure controlled by a electric solenoid in three stages, the oil pressure is directed to a piston which holds down an exhaust valve slightly approx 2.85-3.5mm.
The three stages of exhaust brake on a six cilinder engine activates two cylinders at a time, cylinders 1-2 stage one, cylinders 1-2-3-4 stage two, and 1-2-3-4-5-6 stage three.
A Volvo engine brass or VEB works kind of the same only it uses a separate lobe on the camshaft to open the valve for engine braking...
Hope this helps..
Feb 05, 2016 | 2013 Suzuki Grand Vitara
Intermittent opening and closing of Exhaust Valve
have the exhaust brake tappets adjusted
you haven't mentioned engine size or type so I am talking about jacob brake or dynatard brake
it is possible that when the engine oil viscosity is heavy that the clearance is nit enough
take it in to a service center for as better diagnosis
Sep 04, 2015 | Cars & Trucks
How to engage exhaust brakes
I guess you are referring to a heavy vehicle engine
you will have to come back with engine type , jacob or dynatard brake system or exhaust flapper as a exhaust brake control
Jul 21, 2015 | Cars & Trucks
What is the meaning of jacob
Jacob
The name Jacob is a boy name!
Biblical Meaning:
The name Jacob, In Biblical the meaning of the name Jacob is: That supplants, undermines, the heel.
American Meaning:
The name Jacob, In American the meaning of the name Jacob is: That supplants, undermines, the heel.
Hebrew Meaning:
The name Jacob, In Hebrew the meaning of the name Jacob is: He grasps the heel. Supplanter.
People with this name have a deep inner need for quiet, and a desire to understand and analyze the world they live in, and to learn the deeper truths.
People with this name tend to be orderly and dedicated to building their lives on a solid foundation of order and service. They value truth, justice, and discipline, and may be quick-tempered with those who do not. Their practical nature makes them good at managing and saving money, and at building things in the material world. Because of their focus on order and practicality, they may seem overly cautious and conservative at times.
Oct 13, 2014 | Games
How do i fix a retarder on a mack trident , it only works on the half setting
Hello Roger,is it a mack dinatart or Jacobs engine brake , what I found in the past its the switch it self , but you may have to look under valve cover, there may be a wire off there or outside valve cover or the electeic selonoid on exhaust valve is bad what year is it and motor size ? im really trying to help.
Woody
Sep 28, 2014 | Cars & Trucks
My dish remote SAT key won't light up?
This conversation with Dish Support fixed my problem...
Genne Rose (ID: N1D): Hi, my name is Genne Rose (ID: N1D). How may I help you? Daniel Jacobs: My remote won't pair with my Dish DVR Genne Rose (ID: N1D): I apologize for the inconvenience. It will be my pleasure to help you with your issue today. Genne Rose (ID: N1D): Thank you very much for letting me know your concern. We appreciate your time and effort in contacting us regarding this matter. Rest assured, I will help you all throughout this chat session. Genne Rose (ID: N1D): Thank you for providing your account information and PIN when launching the chat. I have your account loaded and have verified your information. Genne Rose (ID: N1D): The following steps will walk you through the process of addressing the remote to your Hopper.
• Please press and release the SYSTEM INFO button on the front panel of the receiver.
• Then press and release the SAT button. The SAT mode button should then light up with a series of beeps.
• Please verify the remote is now working by pressing the CANCEL button. Daniel Jacobs: yes -- the SAT light lights up Genne Rose (ID: N1D): Thank you. Genne Rose (ID: N1D): Great. Genne Rose (ID: N1D): Have you done that already? Are you finish? Daniel Jacobs: yes Genne Rose (ID: N1D): Thank you. Genne Rose (ID: N1D): Is it working now? Daniel Jacobs: no Genne Rose (ID: N1D): To check, using dish remote, please press and release SAT button, then GUIDE button. Daniel Jacobs: i had already tried that with no success Daniel Jacobs: that doesn't do anything Genne Rose (ID: N1D): I apologize for the inconvenience, Daniel. Genne Rose (ID: N1D): Can you try to reset your receiver by pressing the RESET button on the front panel of the Hopper? Daniel Jacobs: I've done that once, but I can try it again if you want Genne Rose (ID: N1D): Yes, please. Thank you. Daniel Jacobs: oKAY, It's resetting now Genne Rose (ID: N1D): Thank you. Genne Rose (ID: N1D): Right after the reset, please do that again, Daniel. Daniel Jacobs: Do what again? Genne Rose (ID: N1D): The instruction I have provided above on programming your dish remote to the receiver. Daniel Jacobs: you mean System Info followed by SAT button? Genne Rose (ID: N1D): Yes, Daniel. Daniel Jacobs: It's still "Acquiring Signal" .... Genne Rose (ID: N1D): can you try SAT then RECORD button instead? Daniel Jacobs: Should I wait until it's done "Acquiring Signal" ? Genne Rose (ID: N1D): Yes, Daniel. Genne Rose (ID: N1D): We have to finish first the reset before we can program the dish remote again. Daniel Jacobs: It's still "Acquiring Signal" ... Genne Rose (ID: N1D): Let's wait for it to be completed first. Daniel Jacobs: Okay it's back Genne Rose (ID: N1D): Great Daniel Jacobs: you want me to do SAT then RECORD? Genne Rose (ID: N1D): Yes, Daniel. Daniel Jacobs: I guess you mean SYS INFO and then SAT and RECORD? Genne Rose (ID: N1D): Yes, that is correct./ Daniel Jacobs: nothing happens. Just the SAT light coming on is all Genne Rose (ID: N1D): Alright. Thank you. Genne Rose (ID: N1D): Now, can you try to press and release SAT button then GUIDE button. Genne Rose (ID: N1D): Are you able to pull up GUIDE Menu ? Genne Rose (ID: N1D): Or press the Menu button? Daniel Jacobs: Nothing happens -- it's not paired Daniel Jacobs: The sys info screen says "No Remotes Connected" Genne Rose (ID: N1D): I'm sorry about that Genne Rose (ID: N1D): Alright. Genne Rose (ID: N1D): Can you do this? Genne Rose (ID: N1D): Let's deprogram your dish remote.1. Press and hold the SAT mode button until all mode buttons light up. 2. The SAT mode button will begin blinking. 3. Press and hold the RECALL and 0 (System Wizard) buttons at the same time for 3 seconds. 4. Press the SEARCH button. 5. Press the VOL + button. 6. Press the STOP button, then wait 5 seconds. 7. If de-linking is successful, 3 descending tones will be heard from the remote. Daniel Jacobs: I heard the descending tones Genne Rose (ID: N1D): Great. Daniel Jacobs: ok Genne Rose (ID: N1D): Now, can you check if the remote is now working on the receiver? Genne Rose (ID: N1D): try to press and release SAT button then GUIDE button or Menu button. Daniel Jacobs: It looks like it might be working Genne Rose (ID: N1D): Perfect! Genne Rose (ID: N1D): You did a great job, Daniel. Genne Rose (ID: N1D): Is it totally working now? Daniel Jacobs: Yeah, I think so -- I got the Guide on the screen Genne Rose (ID: N1D): Awesome! Daniel Jacobs: thanks Genne Rose (ID: N1D): It is perfectly working now. Genne Rose (ID: N1D): You're most welcome. Genne Rose (ID: N1D): Yapeeeeeeeeeeeeeeeeee !! Daniel Jacobs: right! Genne Rose (ID: N1D): Thank you so much for your patience and cooperation, Daniel. Genne Rose (ID: N1D): For future reference, you can also checkhttp://www.mydish.com/support to access quick and easy troubleshooting steps that will save you time in the future. Genne Rose (ID: N1D): I would like to tell you about DISH Perks. It is an exclusive program that provides DISH customers a lot of extras at no additional cost. You can visit www.mydish.com/perks to see a lineup of the latest freebies. Many perks are available for your benefit. Genne Rose (ID: N1D): Have we addressed all of your concerns today, Daniel? Daniel Jacobs: yes thx Genne Rose (ID: N1D): You're welcome. Genne Rose (ID: N1D): Is there anything else I can help you with today? Daniel Jacobs: no thanks Genne Rose (ID: N1D): Thank you for choosing Chat features and allowing DISH to help and for being big part of DISH. It's our pleasure to assist you today. Always keep in mind that DISH appreciates and value you. Have a great day! Take care and regards to you and your family! :) Happy Holidays! Genne Rose (ID: N1D) has disconnected.
May 12, 2012 | DISH Network Televison & Video
I have automated our Suzuki 1998 My problem is I stopped the engine shuts down I went to the garage and I have replaced fuel pump and it did not help then thoroughly canceled the code lock it did not
If every time you stop it dies this sounds like your brake booster is bad to me if this is what you mean by the above statement if not please go into a little more detail please. But every time you hit your brakes it dies it means something is taking the engines vacuum which only means it is the brake booster.
Apr 09, 2012 | Cars & Trucks
I have a model 1689 drill press with a 33 taper jacobs chuck I need to remove the chuck to put a larger chuck on is the smaller chuck threaded on and if it is, is it RH or LH thread and how do you hold the...
you dont hold it, the chuck is a taper fit and you would need wedges to remove it. the newer chuck would also have to have the same taper to work. if replacing the new chuck you would need to make sure the parts are clean, use a brake cleaner and a paper towel to clean them and then they would press together. Let me know if you still need more assistance.
Jan 13, 2010 | Speed Clausing 15" Variable Floor Model...
2002 Explorer Gear Shift stuck
Start with the brake switch because that is what controls the part lock solenoid. The odds that both the lock solenoid and the brake switch went bad is negligible.
Hope this helps
Aug 20, 2009 | 1999 Chevrolet S-10 Pickup
Caterpillar 3406 Engine Logo
19 people viewed this question
Top Caterpillar Electrical Supplies Experts
gbob59
Lawrence Oravetz
ray gallant
Are you a Caterpillar Electrical Supply Expert? Answer questions, earn points and help others
