Question about Frigidaire Kitchen Ranges
NEED TO REPLACE BOTTOM PANEL
NEED TO GET A BOTTOM OVEN PANEL BELOW THE LOWEST RACK. THE PART NUMBER IS 316400601 FOR A NEW FRIGIDAIRE MODEL FGEF3055MF-- HOW DO I TAKE THE BOTTOM PANEL OUT AND REPLACE IT WITH A NEW ONE? PLEASE ADVISE
  • 52 Answers
SOURCE: frigidaire oven will not heat up
here is a list of error codes that may or may not be displayed by the oven.
Frigidaire Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F2 Oven temperature too hot Check and replace oven temperature sensor (RTD). F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F4 Shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F6 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F8 Oven door lock failure Check lock relay and door switches.
Posted on Jan 29, 2008
  • 184 Answers
SOURCE: frigidaire oven door locked
SOME RANGES ARE DESIGNED TO LOCK IF THE CONTROL SENSES A TEMPERATURE EXTREME. IF THERE IS A FAILURE OF THE SENSOR THAT MAKES THE CONTROL THINK THE TEMP IS UP, IT WILL LOCK THE DOOR TO PREVENT INJURY. REMOVE THE BACK PANEL AND FIND THE OVEN SENSOR LEADS COMING OUT THE BACK OF THE OVEN. DISCONNECT THE SENSOR AND CHECK THE RESISTANCE. AT ROOM TEMP IT SHOULD BE SOMEWHERE AROUND 1084 OHMS. IF IT IS NOT CLOSE,
THE SENSOR IS BAD. PLUG IN A NEW SENSOR AT THAT CONNECTOR AND THE DOOR SHOULD UNLOCK. THEN GET INSIDE THE OVEN, REMOVE THE OLD SENSOR, AND REPLACE IT WITH THE ONE PLUGGED IN.
Posted on Apr 04, 2008
aborcass
  • 2651 Answers
SOURCE: trying to find model number of an old Magic chef gas oven
depending on age, sometimes on back, or even under the main top if it lifts up, sounds as uf you would need to replace the door hinges
Posted on Nov 25, 2008
SOURCE: How to replace maintop (cooktop) frigidaire oven FGFG79GBA
To remove the main top first remove the grates,
burner caps and burners. Using a ¼” socket
wrench or nut driver remove the mounting
screws at each burner orifice assembly.
Insert a putty knife or similar tool between the
main top and manifold panel near the outside
of the front corner. Push the putty knife toward
the rear to release the maintop mounting clip.
Repeat for both sides.
When the mounting clips are released the front
edge of the cooktop can be lifted. Make sure
that the orifice assembly does not bind in the
cooktop when raising the top to remove it from
the range.
Lift the front of the cooktop and pull forward to
disengage the back edge from the rear hinge
bracket. The cooktop can now be replaced by
reversing the previous steps.
See Manual at http://www.electroluxtopservicelatam.com/image/Manuals/Services%20Manuals/Preparation/Cooking/30%20Inch%20Freestanding%20Gas%20Ranges%20(5995440277).pdf
Posted on Jan 23, 2009
  • 286 Answers
SOURCE: how do I replace the bottom burner on the oven
You should have wires that connect to the burner. You may have to pull the oven out and remove the back panal to look for the wires.
Posted on Aug 31, 2009
How to get a pf code off . Just installed new control panel and this code is all that shows up. Help it a frigidaire oven mod. Ples389ech
I appreciate your inquiry, J.J!
From what you have described your Frigidaire oven is displaying an error code of "PF" and you just installed the control panel. A "PF" error code stands for power failure. This could be a possible problem with your control panel and power source. You may need to perform a reset on your oven and you can do that by flipping the household circuit breaker off for at least ten minutes. If this does not help resolve your issue I would recommend having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful to you. -Matt
May 10, 2015 | Frigidaire Ovens
I must replace the oven liner on our Frigidaire 30" slide-in range (Model CPES3085KF2). I don't know how to do it and haven't found instructions is there any instructions on this at all
Good Morning Joe Belchoir, thanks for your post!
I see you need assistance replacing the liner inside of your Frigidaire range. Typically, this is not a simple DIY job. I would recommend having a professional technician out to your home for proper disassembly of the inside of your oven and reassembly of bottom panel. This will help you to avoid any personal injury and future issues. Best of luck! -Matt
Dec 31, 2014 | Frigidaire Kitchen Ranges
Top and bottom heating element does not work on Frigidaire electric range ES300
Usually when both elements are not working and everything else is working fine, the problem is your OCU (oven control unit), commonly known to consumers as the clock.
The clock controls the oven and most times does not produce an error code when it fails.
You will need the actual model number from a sticker located on the oven frame when you open the bottom drawer, the sticker will have the model and serial number clearly listed.
Do a Google search for that model number and find the clock.
I've provided a link for what probably is the proper clock but without the full model number I can't say for sure:
http://www.appliancepartspros.com/frigidaire-clock-316207529-ap3764682.html
Apr 05, 2013 | Frigidaire PLEF398AC Electric Kitchen...
I have a double frigidaire oven and i am using the self cleaning and i am getting an err f11 and it just keeps beeping, it will not let me cancel
Unfortunately, an F11 error indicates a short at the keypad. Try unplugging the oven and waiting a minute before restoring the power. If that resets the error, great.
Otherwise, you need to replace parts. Please add a comment with the model number for specific information. Most likely, you need to replace the electronic control unit (clock). However, this error can be a sign of a damaged wiring harness or the secondary control panel in the oven.
If the oven door is locked, you may be able to temporarily unlock it by accessing the switch controlled by the door lock motor. You will need to unplug the oven and pull it out. Then take off the back panel to reach the switch.
I hope this helps. Again please add a comment with the oven model for more assistance.
Dec 10, 2012 | Frigidaire Ovens
Frigidaire microwave oven
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb to the over the range microwave you will need to follow the steps below:
1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the vent grill mounting screws.
3. Pull the vent grill away from the unit.
4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
Note: DO NOT USE BULB LARGER THAN 30 WATTS.
Oct 27, 2012 | Frigidaire FMV152K Microwave Oven
Frigidaire ES340 has uneven heat
Hi - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately two minutes and turn the range back on. Select a normal bake cycle and if issue continues then the unit may possibly have either a faulty element, bad communication error with the main control board, oven sensor, or mechanical thermostat. I strongly suggest contacting a professional to move forward accurately. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage.
Oct 12, 2012 | Frigidaire FEF366 Electric Kitchen Range
I need an oven rack with the measurements of 22 3/4 inches by 16 1/4 inches. How do I find one at a reasonable price and asap?
You can find the rack
Oven Rack - Size: 16 1/2 x 22 3/4 inch.
Part Number: AP2124960
made by FRIGIDAIRE
Our Price: $35.39
Compare at: $42.11
You Save: $6.72
To the following link http://www.appliancepartspros.com/Appliance-Parts/?keyword=oven+rack As you can see you can find many other racks in the same link.
Nov 26, 2010 | Sears 61301 Gas Kitchen Range
I have converted my new frigidaire gas range to propane with the proper kit and all works well except the oven burner. The flame comes into the oven through the baffle holes about to the level of the...
What you do is tighten down the spud on the oven safety valve. themobilian_221.jpg
Get a good wrench and in the case of propane or LP you tighten down clockwise on that spud. Then open the air shutter all the way.
Nov 21, 2010 | Frigidaire Kitchen Ranges
Frigidaire Gallery stove, oven won't heat up (electric)
With the oven OFF, check the resistance of the bake element with a ohmmeter on the lowest scale. Rx1. If your reading is infinate, replace the element as most elements will open circuit when they burn out. They don't short out.
Jul 27, 2009 | Frigidaire Gallery GLEFM397DS Electric...
After 2.5 years and approc 10 uses the bottom element in the oven went out. Is this an expensive item to replace or can a novice person order the part and replace it.
easy get the model number off the stove,look on top panel back or inside the oven door,call your local appliance part store with model number,remove the back panel and you will see 2 leads for the bottom heating element remove leads,inside oven are 2 screws holding element on remove pull out old element replace with new one,let me know how you did,thanks-mike
Jul 15, 2008 | GE Kitchen Ranges
Kitchen Ranges Logo
21 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
