Question about Refrigerators
Westinghouse - 'Aurora' - 390 litre Cyclic Defrost. I want to drill a 13mm hole in the side this fridge, so as to run a beer line from the inside of the fridge to the outside of the fridge. Apart from the wiring to the door operated interior light - is there any other wiring or refrigeration pipes in the side walls?
  • leswood29 Jun 19, 2009
    Thanks heaps for that - I drilled hole 350mm down from top of bottom door and 200mm in from front of fridge, (not the door), no probs - thanks again.
    Have already given a comment - thanks.
  • 157 Answers
The only thing that should be in your way is what you have already talked about. I have the same kind of fridge and I do know that there aren't any pipes in the side wall they all feed in through the back and go towards the bottom of the fridge. and also go up the back wall of the fridge.
Posted on Jun 19, 2009
How do I remove the plastic drip tray from behind my Wesitnghouse Aurora Fridge Freezer.
we had a really bad smell coming from the back of our westinghouse aurora. and yes found it to be emanating from drip tray at the back. To remove this we had to undo 4 clips at the base of black motor thingy, that the plastic drip box sits on. Then we were able to lift whole thing a bit ,(10mm up and 50mm out, approx) so we could tilt everything forward and sweeze and wiggle tray out. then cleaned with bleach. also we unblocked hole inside fridge that allows water to drip into drip tray at back.
Jun 01, 2011 | Westinghouse Refrigerators
Beer tap
Good day,
If it has the condensor coil mounted on the back of the machine.
(black coil) then yes, VERY DANGEROUS. Refrigeration lines run at an angle from the bottom back of the machine at an angle and terminate at the bottom of the freezer door.
This applies to both sides. Hit one of those and your finished.
Jul 21, 2010 | Frigidaire FRT17G4B Top Freezer...
Leaking inside regrigerator
This is a common problem with top mount freezers and an easy repair .Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Apr 11, 2010 | Refrigerators
Can I drill a hole in the side of my westinghouse rj340m fridge .
the most fridges i have stripped the pipes are on the left hand side and the power wires on the right hand side but if the pipe is drilled thru it is only the oil cooled pipes it can be disconnected the important piper are at the back of the frige i hope this will help you
Jun 17, 2009 | Refrigerators
Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Westinghouse 410l fridge trips new RCD's in fusebox
Tripping an earth leakage would indicate a break down of insulation in the windings of the compressor, the possibility of a short circuit in the wiring system or the defrost element down to earth. I recommend you have a certified technician check it out before you have a fire. If the Hoover is in good condition there is no reason not to replace it. Rate me please.
Mar 11, 2009 | Refrigerators
I want to install two beer tap faucets in the side of my fridge
All of wires are located in the bottom. The side walls are just filled with foam. HAPPY DRINKING
Dec 05, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Making Modifications to my Hoover Orchid Collection 480L fridge
if it is a fridge and not a fridge freezer, then there should be no problem in drilling a hole thro the side
Aug 21, 2008 | Hoover Refrigerators
I'm using a kenmore refrigerator as a kegerator and I need to know if there is anything I should be aware of on the side of the fridge walls as I have to drill a hole into it to attach the hose from the...
Any lines that run through the cabinet should go up the back or and/or around the door. I would carefully cut a hole in the liner and pull the insulation out in small peices just to make sure.
Apr 24, 2008 | Refrigerators
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
