Have Kirkland ''Signature'' washer that's maybe 5 years old. It does not agitate. Pulled the top cap off , (and then the inner seal), looked inside to see what was going on down there and AAAAAhhhhh! Dogs not flying out to engage splines! What needs to be done? Should I buy the ''Agitator repair kit, medium length cam'', recommended on another site for a Whirlpool machine? (Spin cycle works fine!) Thanks, Glenn Fry
    President:
  • 1,136 Answers
Hi, Just replace the dogs. Once you remove the 7/16" bolt, the agitator will seperate.
The dogs are the same part# on all models.
Please let me know if I can assist you further.
Vic
Posted on Jun 19, 2009
Agitator won't move
Thes units have litlle plastic dogs that make the agitator agitate, and when they break it will stop.
Remove the agitator and inside there are 3 to 4 plastic dogs or ears and these are more than likely bad.
Pry the agitator cap off by inserting a screwdriver into the cap's notch
2) Pull the inner cap (if present) off - many Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
3) Remove the bolt in the center of the agitator (earlier models used a 7/16" hex-head steel bolt)
On older models, grasp the bottom portion of the agitator and pull the entire assembly out of the washer. (Some recent models allow just the top portion's removal to access these 'dogs')
5) Older models - place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once just the ratchet ***'y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All '4-dog' versions use the 285770 (or #80040) kit, regardless of the cam ***'y style. (Really old agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***'y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***'y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap's rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap's o-ring too - makes it easier to snap into place)dcramer531_112.jpg
Apr 18, 2011 | Kenmore 24042 Top Load Washer
Quite old admiral mega 22 plus topload washer. the machine did not agitate after filling up. I tried various points on the 3 cycle types and it did not spin either. My son tried moving the agitator and...
Yes sounds like you have now disturbed the seal and will need a new one, remove the agitator and inner drum to get at the seals, to remove the agitator pull off the softner cap and remove bolt form down inside.
To remove the inner drum, the top part of the washer needs to be hinged back to gain access, to do this insert a flat balde 4" from each side at the seam with the front panel to release the clips, lid will now hinge back to give access to the drums, on the outer dum there are clips all the way round to remove the top section of the outer drum release these. remove the bolts under agitator to remove the inner drum. you should have access to the seals but it has been a while.
Reason for not agitating in first place is probably the water level switch at the rear of the drum with a small 8mm hose connecting it to the drum.
Dec 29, 2009 | Admiral AW22 Top Load Washer
Whirlpool ultimate care II top load skips agitation turns
I have the same problem, and i think it is a problem with the agitator i pulled mine off, (remove softener insert below that is a seal easily removed and then a 7/16'' bolt) seems a 'clutch' mechanism between base and upper agitators is shot.
Oct 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Model RTW4340SQ0 clothes waster leaves oil-type stains on clothes
Remove agitator cap. Remove bolt underneath. lift off upper agitator and lower. Look for grease under agitator and on splined shaft and clean. Re-assemble be sure to put plastic thrust piece in between upper and lower agitator.
Jun 13, 2009 | Roper RAX4233PQ Top Load Washer
My Kirkland Signature Whirlpool Washer will not agitate or spin and the motor makes a load noise (like something rattling) when the tub should be moving. but it does drain water.
broken coupler. device between motor and gearcase, look under washer behind the motor for small plastic and rubber coupler. may be worn or broken. cheap part/fairly simple fix. parts house will run ou through the process or i can provide details when you are ready.
May 24, 2009 | Washing Machines
LEAKS AND SQUEAKS
If you suspect the leak is from the main drum seal.
To remove the agitator, remove the softener cap by pulling, look inside the agitator, undo the bolt (4) with long socket extension and then lift out.
5e90500.jpg Not sure if you can see the seal ("O" ring at this point, you may need to remove the inner drum.
Isolate the supply.
Lift the top cover by inserting a flat blade approx 4" in at each side at the front to release the two top clips, top cover will lift and hinge backwards out of the way.
To remove the top ring (13) from the drum, unclip each clip around the top untill released, then remove.
to remove the inner drum (10) , unbolt (7) from the inside, lift out inner drum.
Seal (1) should be visible.
Mar 24, 2008 | Maytag PAV2300 Top Load Washer
My whirlpool top loader won't agitate.
Sounds like what you have is a dual agitator, bottom moves back and forth in wash, top acts like a screw pulling clothes down to the bottom of the tub. If so, the agitator dogs are bad, to get to them, pop off the cap on top of the agitator, then reach down inside and pull up a cap in there, then use a socket (I forget the size) and a long extension to unbolt the agitator and pull it out, the dogs are located between the top and bottom sections. They are slightly curved rubbery plastic pieces, 4 total. About an 1 1/2" or so long, one end fits into a hole on the inner part of the agitator and the other end is ribbed to catch the outer part of the agitator during the wash stroke.
Nov 08, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Sep 02, 2007 | Washing Machines
Washing Machines Logo
263 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
