Question about SAMSUNG CLX-3185FW COL LASER MFC Projector Screen
Replace new image unit - SAMSUNG CLX-3185FW COL LASER MFC Projector Screen
Prepare new image unit
dear
the imaging unit;drum unit has lapse its counter life. you have to replace with new one. however if you wish to use further try to get the model crum chip it will refresh the imaging unit.
thanks.
Mar 03, 2015 | Samsung ML 4600 Laser Printer
Need to replace imaging unit . konica c252
http://www.precisionroller.com/imaging-units-for-konica-minolta-bizhub-c252/products.html
push down, slide out, pull tapes and fixtures off new unit(s) and replace. These IU's have chips in them to keep track of life. Another option instead of replacing the unit is to buy just the chip and replace it on the old image unit. This depends on the condition of the existing unit(s).
Jan 07, 2015 | Konica Minolta BizHub C252
Trouble c-2551 call service
Cyan Image Unit (Blue) Pull out cyan image unit not the cyan toner, Shake the image unit along the axis of the unit we want developer and toner spread evenly along the entire image unit. Then re-install. Reset code by closing and opening image unit door, not toner door. Worse case replace the image unit you do get bad ones.
Additional questions:
1.Is this a new unit?
2. Is it OEM or third party?
3. Is it new?
4. Did you chip it?
Sep 12, 2013 | Genuine Konica Minolta Konica Minolta...
C13C0 I/U FUSE CCUT
So you replace the fuse ? on the image unit. what do you mean by CCUT??? YOU CUT THE FUSE when the image unit is replaced a new fuse must go in so the copier will blow it to know it got a new image unit
Feb 10, 2011 | Minolta Di2510 All-In-One Laser Printer
Error code C0F32
This error means Imaging Unit ATDC (automatic toner density control) failure. Open and close the right side door where the imaging unit is. If the code comes back you are going to need Imaging Unit service or possible Imaging Unit replacement. The best option and the cheapest is to locate a new imaging unit and replace it yourself. These units are very easy to change and similar to replaceing a toner cartridge in any laser printer. Just do a search for Di200 Imaging Unit.
Good Luck and Thank You for using Fixya.
Apr 14, 2010 | Konica Minolta DiALTA Di200 Copier
I have a xerox 7750, error code 9-913
This problem occurs when you buy the wrong image unit.
The contact chip that is located at the bottom of the orange plastic is not for the machine. Replace it with 7750 image unit and that should fix your problem. Black is fault 9-910 cyan fault : 9-911 magenta fault: 9-912 yellor 9-913.
Sep 24, 2009 | Xerox Phaser 7750DN Laser Printer
Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
Mar 02, 2009 | Konica Minolta bizhub C450P Laser Printer
Technical Black Imaging Unit Replaced,Error message still shows
These units are automatically reset with a fuse. When you put the imaging unit in it will completes a connection which resets the count then simultaniously blows the fuse. Sometimes the fuse blows before the reset, which is what it sounds like happened here. The machine should print normally but the error will persist until the unit is replaced with a new one. Is the the imaging unit an OEM unit or remanufactured? Whoever you got the unit from should replace it as defective free of charge. If it is OEM you might have to go through Xerox to get it replaced. I don't know if the Big Box stores will.
Dec 04, 2008 | Xerox Phaser 7300DN Laser Printer
Black Imaging Unit
If the machine calls for a new unit, a new not used cartridge must be installed to clear the message
Mar 27, 2007 | Xerox Phaser 7400DN Laser Printer
SAMSUNG CLX-3185FW COL LASER MFC Projector Screen Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
