Question about Sony Playstation 3 (PS3) Console
Start up screen not continuing
Start up screen wont advance to anything?
  • 6,784 Answers
HI, you hard disk drive is failing at this point. you will need to send this unit in for this repair. Sony will need to replace the hard disk. is has failed.
Corrupt hard disk error.
Posted on Jun 19, 2009
My dragon touch 7 inch tablet doesnt start up. the screen goes directly to white and it wont go from there
There are a couple things that could cause that. Does it still have sound? If you can hear the sound continue, it is likely caused by either damage underneath the screen, moisture inside it, heat/sun damage, etc.
Jul 22, 2016 | TabletExpress Dragon Touch 7 Black Dual...
My 96 mercedes s500 wont start
Hi Will, If you can't turn your key past the steering lock then you won't be able to continue turning the key to start your car, Try turning your steering wheel left to right continuously as you turn the key.........I'm not there mate but I hope this helped........CHEERS..
May 06, 2016 | Mercedes-Benz S-Class Cars & Trucks
My Toshiba NB500 wont boot and the screen wont work. I turned it on this morning and it came up with pxe media failure check cable or something along those line now i try to turn it on and nothing happens...
The Hard disk drive was not detected by the system. Turn off the laptop and try to reinsert the hard disk. Start the PC up and go to Bios/Cmos set up by hitting the F2/Del key.. check if the hard disk drive is in first boot set in boot priority device at ADVANCED settings. then exit and save settings.
Aug 16, 2014 | Computers & Internet
Have a newish toshiba satellite c655 laptop. we lost our internet feed for a little while (1 hour) and when it came back on, i tried to turn on the laptop and had to reboot. After reboot I got the start up...
When you boot up the laptop press F8 several times then you will get a Windows Advance Options Menu. Then select Last Known Good Configuration and then press Enter.
With luck Windows will start up normally.
Jun 11, 2011 | Computers & Internet
Windows not starting. everytime i started it it goes to safe mode and say windows did not start. it wont let do anything \.
I suggest you to try Last known good configuration.
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Dec 22, 2010 | Compaq Armada M700 Notebook
My playstation just freezes on start up screen and
hello,
"When the PS3 system freezes and wont play, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
• Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
• If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
• Leave the PS3 system off for 30 minutes to let it cool down.
• If you continue to have issues, you will have to send the system in for service."
May 30, 2010 | Sony Playstation 3 (PS3) Console
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
Dryer wont do anything. The circuit breaker is good, there is power at the outlet. when you close the door and set the timer and push the start button, it wont tumble or anything.
Check continuity through the start button WITH THE POWER OFF. A cheap ohm meter should show a reading through the switch when it is pressed. If that checks good, use the same meter to read from the switch through the start coil of the motor. You should see something around 4 to 10 ohms. No reading, then check the connectors that they are tight.
It is rare that the start coil goes bad because it is only used on start.
Dec 20, 2009 | Cell Phones
Sts 2005 not starting
My Caddy was working fine until yesterday when we went to get in, we couldnt unlock the car with the detector so we ended up using the key. when we did that we had NO Power at all car would not start up.. My husband ended up jumping the car off and it worked. we took it to Advance Auto and the guy tested the battery and he said it was fine... until i went to get in it the next day it did the samething and now im at work and it wont start any suggestions whats wrong?
Jul 10, 2009 | 2005 Cadillac STS
Acer Aspire 5100 Wont Boot To Start....
Try booting in safe mode. you may want to first try loading the last known good configuration.
To get into the Windows Vista Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use yourarrow keys to move to "Safe Mode" and press your Enter key. Let computer boot to safe mode and then shutdown. If problem continues then Start in safe mode again.
After you boot to safe mode then go to Control Panel, System, Advanced System Settings, Advanced tab should be at the forefront. Go towards the bottom of the popup (Startup and Recovery) and select settings. Then in the settings popoup uncheck Automatically Restart. OK and apply everyithing then restart computer. Let me know what happens.
Dec 18, 2008 | Acer Aspire 5100 Notebook
Sony Playstation 3 (PS3) Console Logo
77 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
