Question about T-View T1501S 15 in. Car Monitor
How to hard wire tview headrest monitor - T-View T1501S 15 in. Car Monitor
5 Suggested Answers
JMuskovitz
  • 135 Answers
SOURCE: Back A Car Signal
The speculation on this webpage: http://www.mp3car.com/vbulletin/archive/index.php/t-88625.html makes it sound like it is a trigger to switch the monitor to display a rear-facing camera when you put the car into reverse. You would either wire it to a manual switch (to 12v) or to your reverse lights. Keep in mind, this is not an authoritative answer. Good luck, and let us know if this helps!
Posted on Mar 20, 2007
  • 11 Answers
SOURCE: A/V AND Power wiring diagram
hi on what you have just told us go and get the same cables that you were using in the old car coz this wires are the ones ment for the screen i mean right holms,right jack pins for it . good luck .
Posted on May 11, 2007
SOURCE: CANT HOOK UP MY TVIEW T56UN/HR 5.6 LCD MONITOR
THE S-VIDEO LOOK ALIKE IS ACTUALLY A PIN ADAPTER FOR AV JACKS. THE DVD MAKERS USE SPECIAL CONNECTIONS TO COMPLICATE ADDING TO MIXED SYSTEMS. (THEY WANT YOU TO BUY ONLY THEIR PRODUCTS!) REPLACEMENT ADAPTERS ARE AVAILABLE ONLINE @ http://www.tview.us/
Posted on May 15, 2009
  • 1632 Answers
SOURCE: need a power plug for 17" tview flip down monitor
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
Plays video then goes to black screen.
If everything is installed correctly, front and rear viewing may be available only with your vehicle not in motion. Only rear viewing may be available in notion. It's a safety issue.
Apr 08, 2014 | Tview T102SVBK 10.2 inch sun visor monitor...
When I put my DVD into my Tview headrest unit, it runs and runs and runs and then comes up and says no disc
If that only happens with one specific DVD, the problem is that DVD. Try playing it on another DVD player and see what happens.
If your TView won't play any DVDs, try turning the power off, blowing some compressed air into the unit, and turning the power back and see if that makes a difference.
Jul 01, 2010 | T-View TView (DVD1006) In-dash DVD Player...
Jan 18, 2009 | T-View TView (T606HR) 6" TFT/LCD Monitor...
Connecting headrest monitors to Kenwood DDX-6019
Youll have to run sets of cables from your head unit to the seats, youll prob only need video, power, and ground if the sound will come from your speakers. For the same display on either monitor run to first position then link the 2 monitors.
May 10, 2008 | Sony XVM-R70 7 in. Car Monitor
TView headrest dvd player
hi hallow then their is a problem in passing power supply or receiving power supply r some where the connection may lost which unknown to u so please refer it once again and see the battery connected perfectly are not. u explained u r problem very well but such problem can solve by cheaking the instrument practicaly so if still u r problem is not solved its better to consult the expert near to u directly
Feb 24, 2008 | Car Audio & Video
Wiring harness
log on to tview.us and contact them or call them at 1-832-251-2000 they said they could send me a cable for my tview 5800SV for $25.00 but I would have to send in a money order before they would process the order. there is no simple on line order form or cc by phone option, havent done it yet but it can be done
Oct 30, 2007 | T-View T700HRBK 7 in. Car Monitor
May 03, 2007 | T-View T-6500HR 6.5 in. Car Monitor
T-View T1501S 15 in. Car Monitor Logo
35 people viewed this question
Top T-View Car Audio & Video Experts
xxxxxx xxx
Are you a T-View Car Audio and Video Expert? Answer questions, earn points and help others
