Question about Racing Electronics Radio Communications
Scanner has new batteries put in and it will not turn on
Why wont my 2003 vw newbeetle convertible start,i put a new battery in it,doesnt start,engine turns but wont start
use a scanner to reset the cpu program in the ecm as the immobiliser has been corrupted by the battery removal
Mar 31, 2015 | 2003 Volkswagen New Beetle Convertible
Crossed cables jumpstarting 95 Tacoma replaced alternator fuse link got a new battery and still won't start
You may have blown the computer(ECM). Newer cars are somewhat protected from this. But older ones weren't. Put a scanner on it. If the scanner doesn't read it, you've blown the ECM
Mar 29, 2015 | 1995 Toyota Tacoma
My 2011 Dodge Grand Caravan had to have a new
use a scanner to reset the corrupted section of the ECM /cpu program
Oct 06, 2014 | 2011 Dodge Grand Caravan
My Radio Shack Pro-82 Scanner batt. went dead , now I have no sound
That means you have to put new batteries in your scanner... or recharge your rechargable batteries but if you use rechargable batteries use your yellow battery cradle for rechargeable batteries and your black cradle for alakline batteries....foe pro 82...
Feb 28, 2011 | Radio Shack Pro-82 Scanner
Handset green light is flashing on and off and there is no red light. When I try to scan a bar code with the handset it does not scan. How do I replace the battery in the handset?
Hi, there are detailed instructions for replacing the battery in the LS4278 Product Reference Guide on page 27 of 414.
Use a philips screwdriver and turn the screw in the base of the scanner counter clockwise to remove the latch at the bottom of the scanner.
Turn the scanner upright to slide the battery out.
Disconnect the battery clip.
Reattach the battery clip.
Make sure the new battery is securely in well of scanner.
Attach and close latch.
Use philips screwdriver to press down gently and turn screw clockwise to lock latch in place.
Feb 08, 2011 | Symbol LS 4278 Barcode Scanner
No voltage at the engine coolant temperature sensor. On a 1998 Chevrolet Cavalier. Had it check and got an error code P0118. Put a new engine coolant temperature sensor and put new dex-cool coolant. I...
ever since 1995 you have to turn off useing a obd2 scanner, if you do not have one, you can go to any auto parts store and they will erase the code for free. by having the light still on the computer thinks it still has an error. good luck Toolman,
Jan 26, 2010 | 1998 Chevrolet Cavalier
Batteries run down in a little over half a day in my new uniden BC72XLT scanner, is it batteries, charger or scanner?
its most likely the scanner. i had one that used up batteries pretty quick. my advice would be to get rechargeables, and get 2 sets of batteries so when one set runs down you can put the fresh set in the scanner
Jan 13, 2010 | Uniden BC72XLT Handheld Scanner
Hand held scanner pro-25 wont turn on
are the batteries in the right way
May 24, 2009 | Radio Shack Pro-96 Scanner
Radio Shack Pro Scanner
I know that if you turn your scanner off over a few days you can loose your frequency # or it will lock the channels out. if they or l/o just unlock then. I also know that all police and ect. went digital, you would to have a scanner that is digital. When they changed to digital some for the frequency # have changed. I had to get the new ones and put them in.
k.ditterline@yahoo.com
Jun 08, 2008 | Radio Shack Pro-97 Handheld Scanner
Radio Communications Logo
Top Racing Electronics Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Racing Electronics Radio Communication Expert? Answer questions, earn points and help others
