Question about GE JE1540 Microwave Oven
Fam comes on microwave when you open the door
Should the light come on when the door is opened
think so but then who knows what an engineer does or why
Mar 02, 2015 | Frigidaire FFCM1134LB Microwave Oven
Ge pvm1870DMWW
Verify the door micro switches.
Aug 30, 2017 | GE Microwave Ovens
GE PVM1870DMWW
Check those 3 micro switches in the door latch assembly
Nov 15, 2017 | Microwave Ovens
Light fails to operate with door open
If the light comes on during cooking then the bulb is ok.. in all probability the problem is the door switch that senses when teh door is open and activates the light... Hope that helps..
Aug 15, 2008 | Frigidaire GLMV168K Microwave Oven
Microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Comes on when Door is Opened
It sounds like a problem with the door switch or mount or the control panel. I've attached an exploded view of the oven which shows the door switches and mount. They're located behind where the door hooks go into the chassis. You can find our safety and disassembly instructions at our site via my link here: http://tinyurl.com/yzjozk If it's not switch-related, then you may have a shorted component on the control board. We repair these for customers nationwide for $32.50 postpaid in most cases.
Jan 18, 2007 | GE JE1640 Microwave Oven
Microwave works with door open
If the top is open, the upper door switch should be open and the high voltage section should not be energized. That's the way it's *supposed* to work. But that buzzing is worrysome! Does the turntable turn during this condition? Does the inside light come on? How about the fan? If not, then I would doubt that it's cooking. If so, some models will do this. It's not uncommon to notice that the fan and light will try to come on for a split second when you shut the door. This would not indicate a problem. It has to do with the timing of the door switches and a replay on the board. If it's still under full warranty, it wouldn't hurt to call a GE-authorized servicer.
Nov 07, 2006 | LG LRMM1430 Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
