Question about Samsung SCX4623F Laser All-in-One Printer
Paper jam but no paper jam
Sometimes would get "door open, close it" message
  • 220 Answers
SOURCE: paper jam 1 - samsung clx 2160n
fuser needs replacing.
Posted on Jul 08, 2009
  • 22 Answers
SOURCE: samsung scx 4100 just decided
Its a mechanical problem.
The best solution for that is to call a service technician nearest to your place.
Posted on Jul 28, 2009
SOURCE: paper jam --samsung SCX-4828FN
i found that paper jam was in the middle of the mechine. i opened the front door and removed papers.
Posted on Sep 18, 2009
Firetree
  • 179 Answers
SOURCE: Our printer says paper jam
This can happen when there has been an actual paper jam, and in the process of clearing the jam and removing the paper one of the optical sensors inside the paper path has been damaged, thereby giving the alarm when there is no paper in the path.
Repairing this situation requires a skilled technician and dismantling the machine. This very problem happened with my own Canon Pixma MX860, a machine I dearly loved and had only owned for six months...but the cost to repair it was as much as I paid for the printer.
I know that isn't what you wanted or hoped to hear, but I also hope it was helpful.
Posted on Jan 08, 2011
  • 304 Answers
SOURCE: the printer say paper jam
First remove the toner cartridge.
Move manually the gear of the toner cartridge (big gear) forward and place the cartridge in your printer and try again.
Posted on Aug 15, 2011
Paper Jam 0 , OPEN/Close Door Message Samsung SCX4100
seems as if the motor responsible for taking in the paper has stopped working and may need to be replaced
Dec 26, 2016 | Samsung SCX-4100 All-In-One Laser Printer
Message "Door is open. Close the door" appears every time I try to print from my Samsung CLP325 Laser Printer. The back door is not open. Is there another door? I have tried re-opening and re-closin
This is the classic symptom of a small piece of paper that was torn when the jammed paper was pulled out. Remove the cartridges, open the door, remove the paper tray, use a flashlight to look. Number one tip, when you remove paper from a jam, smooth it out and make sure it is complete.
Feb 21, 2018 | Samsung CLP325 Laser Printer
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
Printer keeps saying it has a paper jam and to remove the jam from the back. There is nothing there! I think it just wants me to open and close the rear door, but that only fixes it sometimes. How do I...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 22, 2010 | Ricoh Aficio CL1000N Printer
Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
We keep getting a message -paper jam check open rear door. checked, no paper jam, opening and closing rear door will allow the print job to go through. It will work for a few print jobs, then the same...
It's probably a sensor on the fuser. There are 2 and sometimes they get stuck and just closing the rear door hard will release it. Replace the fuser.
Dec 08, 2009 | Dell W5300N Laser Printer
New out of the box 13:20 error paper jam there has never been any paper in machine we're just setting up. open and close front, then theres a fuser jam lift and close top, front door again.We have paper in...
PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
Jun 24, 2009 | HP LaserJet 3600n Printer
Paper jam. we removed the major portion of it. bit of paper is inside. we can't find out that. display shows 13.20.00. we removed front and back except toner catridge. what we have to do.
Try this linke below.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=411171&prodTypeId=18972&prodSeriesId=411171&objectID=c00642524
Or i cut and paste text, but you should view pictures. If you cannot get to it from link. Try typing "Paper jams alternating between front and back door" It should be first link from HP about a 3550.
HP Color LaserJet 3500, 3550, and 3700 Series Printers - Paper Jams Alternating Between Front and Back Door Issue Description Customers may see paper jams error messages with no paper seen in the paper path. The message will alternate between check the front door and the back door. Workaround The release lever engagement tabs on the rear door can be bumped into the in-correct position. The purpose for this tab is to re-engage the fuser release levers as the rear door is closed. When one or both of these are left in the in-correct position the printer goes into a cycle of alternating between a "Jam in the Front Door" message and "Jam in the Rear Door" message. There is no paper present in the paper path when this happens. When a customer gets the "Jam in the Front Door" message and opens the front door, no paper is found. After the customer closes the front door, they get the "Jam in the Rear Door" message. When they open the rear door, find not paper (even pull out the fuser), and close the rear door, they get the "Jam in the Front Door" message. This cycle will continue
Placing both engagement tabs in the "Correct" position solves the problem and allows the print job to continue.for as long as the customer is willing to keep checking.
Sep 27, 2007 | HP LaserJet 3550 Printer
Samsung SCX4623F Laser All-in-One Printer Logo
97 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
