Question about Ibanez Music
How to wire Ibanez RG5EX1
I have humbucker inf3 neck,a infs3 middle single coil,and a duncan 5 wire humbucker for the bridge,a 5way lever switch,and two pods. ive searched for hours on the internet for a solution with no avail.please help.....thanks
4 Suggested Answers
TeleFurb
  • 16 Answers
SOURCE: how to wire new humbuckers in a dean vendetta xm
Scroll down about half way
http://www.1728.com/guitar.htm
Posted on Aug 26, 2009
sparky1500
  • 1066 Answers
SOURCE: i recently purchased a dean "dime-razorback"
here is a wiring diagram for another washburn. its not gonna be exactly like your set-up, but it should be pretty close. its really not that hard to rewire a guitar, i did it when i was like 12 years old, and the worst thing i did- wired the volume pot backwards. the diagram im seeing is differrent from any guitar ive prevously worked on, but it should be pretty accurate for a washburn.
http://i83.photobucket.com/albums/j298/BlueBuddhaibanez/Picture12-1.png
those dimabag darryl guitars, lke the bronze ones, are really cheaply made.
Posted on Nov 26, 2010
  • 5603 Answers
SOURCE: I need wiring diagram for
Search this site for one matching your configuration:
http://www.guitarelectronics.com/category/wiring_resources_guitar_wiring_diagrams/
Posted on Jan 12, 2011
I need the wiring diagram for an Ibanez AS153 semi hollow body, where can I get one?
the 153 is wired like a Les Paul or SG
2 humbucker, 2 vol, 2 tone
with the addition of a 3 way coil tap for the neck pick-up
wired similar to:
http://www.guitarelectronics.com/product/WIRING_MOD_HB0066/Guitar-Wiring-Mod-HumbuckerOFFParallel.html
Aug 16, 2016 | Ibanez Artstar Series AS153 Semi-Hollow...
Tone changes in pearly gates pick up
What you describe sounds like pickups fighting against each other meaning, does this occur when using pickups individually or together? This is normal when using more than one pickup together, if it occurs in single mode, something is wired wrong. Another thing is, If using single, are you splitting coils? Individual coils wired wrong can do this, a bad pickup selector switch can also. A loose wire or fiber touching the tone pot capacitor or ground could also. A dead coil on a humbucker can as well. I'm guessing that you are using these in combo meaning a possible pickup selector switch may not be switching properly. The player's level of experience is also in my mind since, all of my guitars do the exact same ONLY when I use more than one pickup. I hardly ever use more than one at a time unless I'm playing a strat.
Mar 28, 2014 | Seymour Duncan ShPg1 Pearly Gates Pickup...
Guitar pickup wiring diagrams
That guitar features two single coil pickups when stock. If, however, you or someone else installed a 4 conductor humbucker in the neck and you want to access other tonal options, check out the Seymour Duncan web site- they have tons of easy to understand diagrams- you just need the soldering skills to make use of them!
Make your selections on this page and good luck!
http://www.seymourduncan.com/support/wiring-diagrams/
Dec 08, 2013 | Fender Squier Classic Vibe Telecaster 50s...
Push pull guitar diagrams
check at seymourduncan.com...your humbucker needs to have 4 conductors in order to tap coils...which is what I presume you want to do with the push/pull...
relative pickup wire colors:
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=coil_splitting
now match the Fender colors to the Seymour Duncan wirs and check this out:
Need adiagram for replacing 3 wire factory humbuckers with 4 wire seymour duncans
These are for the seymour duncan JB pickup which uses an extra switch for a coil tap. If you tie the leads of the switch you can avoid using it in which it would become a normal humbucker.3_8_2013_7_29_41_pm.jpg
Sep 26, 2011 | Music
I bought a yamaha electric it has two double pick ups and a single in the middle the volume knob was no good so i changed it when i opened it up they had the wiring all messed up it has a five pos. switch...
my guess is two positions at one end work(aka 1 and 2, or 4 and 5)? if yes, then 2 of the pickups are wired wrong. (if 1 and 2 work, which are the forward positions, then the middle and bridge pickup are wired wrong, etc.) the problem is there is a variety of 5way switches that are different. i would guess yours is "import" style. are there 8 lugs in a single row on the back of the switch? if yes, you probably have an import switch. best i can do in text is tell you that the middle two lugs are common. this means one goes to the volume pot, and there is probably a little jumper between the two lugs as well. now there are 3 lugs on either side of those 2 common lugs. one set of 3 will probably run to the tone pot in some fashion or be empty. the other set of 3 lugs is for the pickup lead wires. it sounds like at least one or two of those lugs are empty but shouldnt be, or are wired wrong. i cant tell you colors of your wires without seeing it, but this is how it should be, with the exception that the tone knob will probably be on the bottom 3 lugs somewhere. 1 would be the neck pickup, 2 the middle, and 3 the bridge hope this helps, feel free to post a pic of your wiring, etc xadioriderx.jpg
Jun 10, 2011 | Yamaha Electric Guitar
I did not get a manual with my Evo XM guitar and amp pack, and my experience with electric music making is limited at best, so here is my basic question; what are the functions of the two knobs and the...
I don't know precisely, but since it is a dual humbucker and only has 1 switch and 2 knos, the knob nearest the neck is probably the volume, and the other is the tone. The switch should select which pickup is in use, towards the neck for the neck or rythym pickup, and the other way for the bridge or lead pickup. If it has a centre click position, that will be both pickups on together. If one of the knobs has a pull position, that will likely be a single coil switch for the lead pickup.
May 03, 2011 | Dean Evo Xm Electric Guitar Natural...
Music Logo
142 people viewed this question
Top Ibanez Music Experts
Michial Gueffroy
Wayne Tolonen
cwradio73
Are you an Ibanez Music Expert? Answer questions, earn points and help others
