Question about Shaw Robert RS-9420 Thermostat
Lost visuals on thermostat - Shaw Robert RS-9420 Thermostat
GE profile dryer,Runs fine but no heat
need to have the heat element checked with a multimeter and visually if u can and look for burns and corrosion and breaking of the wire connections. Also have the thermostats checked, Im assuming its electric and not gas? the thermal cut off may be bad and the hi-lo thermostat, these can shut heat off from the dryer. Ive replaced the element on my G.E profile and it wasn't all that hard rather simple.
Sep 13, 2014 | GE Profile Gas Dryer Model Dpsb513gb0ww
My 1996 volvo 960 is over heating after i replaced the thermostat. What else could be causing this
check which way you put the thermostat in. The body of the thermostat has to face the water (in head or block) for the heated water to make it work. In the wrong way and it blocks off the water flow and the care will over heat.
Dec 31, 2013 | Cars & Trucks
Not heating water
Check to make sure you have 220 Volts to the top of the upper thermostat. Also, if there is a reset, it is going to be a red button on the upper thermostat. Google electric water heater thermostat and you will get plenty of visuals on how they are positioned & wired. With no power (end the wires pulled off the elements), Ohm out the elements which should read under 20 ohms. This will prove that your elements are good. The only other electrical to go wrong is the thermostats.
Dec 18, 2013 | Northstar Water Heaters
RTH6580WF how do i reset to factory default?
It is actually an extensive process to reset or reconnect with a new wifi setup. To try to explain it would probably be confusing and couldn't give you step by step. Here is the link to the installation instructions that explain it perfectly and visually, https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2718EF.pdf
Hope this helps!
Dec 07, 2013 | Honeywell International Wi-Fi Programmable...
After changing thermostat, car is running to cold
Did you install the thermostat in the same direction as it came from Factory? Did you used a new rubber gasket on the thermostat?
Can you Test the thermostat in a pan of hot w?ter, to visually verify that it opens as intended (at 195°F)?
Amclaussen.
Mar 30, 2013 | 2006 Dodge Stratus
Screen of my cam (Sanyo Xacti VPC A5) has lost its visual after fell down from table..
Cameras do not fair very well from even slight impacts, it will need to be looked at by repair shop.
Jan 26, 2013 | Sanyo Xacti VPC A5 Digital Camera
Dryer gets severely hot on top and rear of machine,is this normal?
Reasons for overheating can include:
1. Shorted heater coil
2. Bad operating thermostat
3. Worn drum seals (felt seals in back & front)
Use a multimeter to check the coil and thermostat for continuity
Visually check the felt drum seals
Nov 21, 2010 | Frigidaire GLER642A Electric Dryer
Hi my son's 92 Honda LX smelled bad this morning like the engine was overheating Son dumped water into resevoir and drove car back home. The engine was steaming. After letting it cool. Visual inspection...
FLUSH COOLANT SYSTEM REPLACE THERMOSTAT AND RADIATOR PRESSURE CAP.BESURE TO USE 50/50 ANTIFREEZE AND WATER.TO RAISE BOILING POINT.PLAIN WATER WILL BOIL AWAY OR EVAPORATE CAUSING COOLING LOST WHICH MAKE ENGINE OVERHEAT.
Aug 10, 2010 | 1992 Honda Accord
Shaw Robert  RS-9420 Thermostat Logo
46 people viewed this question
Top Shaw Electrical Supplies Experts
obsteiner
Gil Shultz
Are you a Shaw Electrical Supply Expert? Answer questions, earn points and help others
