Question about Sierra Online, Inc. Card Zone Deluxe for Windows
Sierra the card zone install on windows 8 - Sierra Online, Inc. Card Zone Deluxe for Windows
Want to know which digital cameras are compatable with windows 8
Are you saying the supplied software does not install in Windows 8? Being as the camera uses SD memory card, SDHC memory card, SDXC memory card, then Windows 8 will be able to read those cards. As for which cameras are compatible with Windows 8, they all should be.
Apr 05, 2014 | Quantaray 28-300mm F3.8-6.3 Autofocus Lens...
Msi 7267 ver
card not compatible with the other operating systems. Happens.
Aug 22, 2017 | Computers & Internet
I have a microsoft visual C++ runtime library problem. it says "runtime error!" program: D:\sierra\cardzone|planner.exe abnormal program termination
Hello there,
you need to update or repair the runtime error here is a link telling you step by step how .
http://support.microsoft.com/kb/307817
Jan 25, 2011 | Sierra Online, Inc. Card Zone Deluxe for...
My disk is 11 years old.will windows take it
i just did a search online, and there seems to be a newer version of the same program that you can get from amazon.com ( its called something else).
But if you have a computer that has the Operating system XP or Vista you can try it and it should work.
But i would get a new copy just in case the cd is corrupted from time.
Sep 20, 2010 | Sierra Online, Inc. Card Zone Deluxe for...
MasterCook 6.0 will not open up
It Took Me About 40 min. to figure it out
1. install master cook 6.0
2. open sierra on c drive c:\sierra\mastercook6\program
3. delete msvcp.dll file
mastercook 6.0 will now run
there will be no cookbooks
1. goto file\open add it will list all the cookbooks
2. open each one and then everything works as normal
Apr 11, 2010 | Sierra Master Cook Deluxe 5 Full Version...
I installed a Sierra Wireless MC8775 WWAN device in my HP NC6400 laptop under Windows 7 ultimate 64 bits. BIOS recognize it (I see it in the BIOS setup). I've installed Sierra Wireless Watcher program...
here is the real story. (right?)
its old, NC6400 its really a COmpaq, (hp) circa 2006?
it came with XP not W7,so.... lots of things will be wrong.
it has no wireless at all, no wifi, and for sure no 3G
so you bought the 3G device.
but they are not all the same, is your PC USA PC and is the
MC8775 , the USA version (uses USA frequencies FCC allowed)
"say world roaming" but is complex.
did you contact them and ask for help.
only there hardware and there software works.!
best is to talk to the makers. in all cases , non HP systems.
https://www.sierrawireless.com/company/newsroom/pressreleases/2006/05/05-08_sierra_wireless_introduces_next_generation_hsdpa_embedded_module/
https://www.sierrawireless.com/sitecore/content/developer-zone/resources/#tags=mc8775
May 13, 2017 | HP Compaq nc6400 Notebook
Replacement of dist with paint marks removed
The codes will stay in place till cleared by a scanner. Take it to Auto Zone and they will clear the codes for you free of charge
Mar 19, 2010 | 1998 GMC Sierra
I'm tryin to install the sierra wireless card 598 on win 98 manually. Does anyone know how to do
Hello sir, hi, installing a USB device on windows 98 is kinda hard but possible. here are some things that you should do:
  1. you may need the sierra CD device driver that comes with your wireless card.
  2. next is that your PC should support USB 1.1 or 2.0. If you are using windows 98, make sure that your USB port is working fine, you can insert a flash drive to confirm if your usb port is working.
  3. depending on the setup files they may need you to plug in the device as the setup file loads the driver or later.
  4. run the sierra CD setup file to install your wireless card. (hope win 98 supports this device)
  5. after the setup, plug in your wireless USB device, windows 98 should detect it.
If things didnt work out as listed above, do it setup several times, ............ still no progress call your dealer for proper installation on your PC.
Nov 09, 2009 | Sierra Wireless 598U USB Modem
Sierra Online, Inc. Card Zone Deluxe for Windows Logo
22 people viewed this question
Top Sierra Online, Inc. Video Game Consoles & Games Experts
James Wishart
Edward Talavera
Edward Talavera
Charles Applebaum
Level 1 Expert
Are you a Sierra Online, Inc. Video Game Console and Game Expert? Answer questions, earn points and help others
