Question about Dryers
My Samsung electric dryer model # dv210aew/xaa runs fine but won't heat and shows an error code of dp16, which we can't find reference to anywhere. We've checked the vents, air flow through the dryer,
Dryer is just over 3 years old. The cooling light is on an the drying light is blinking. The clean vent symbol comes on when the dryer is powered on. Vents are clear
  • Teara Curry
    Teara Curry Apr 18, 2014
    Is that what the code stands for?
  • Joey Bain Apr 19, 2014
    Yes it is
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Door switch and heating element
Posted on Apr 18, 2014
  • Teara Curry
    Teara Curry Oct 16, 2014
    Thank you Joey Bain. There is a problem with the door switch but the dryer wouldn't heat because one of the two fuses it's wired through blew. Replaced the fuse and the dryer works again
4 Suggested Answers
  • 5 Answers
SOURCE: Dryer takes too long to dry a load
Have you checked the lint screen? pull the lint screen out and remove the lint then hold flat and pour water on it. Does the screen hold the water or does the water flow through? If it holds water, then you must actually clean the film that has coated the screening material. Use dish soap and scrub lightly then rinse clean. and check again.
Posted on Apr 02, 2009
  • 190 Answers
SOURCE: Dryer not generating heat and drying clothes...
Dear customer,
                We recommend you to do the following checks when your dryer isnt generating heat..
  1. Check for proper air flow
  2. Test the safety fuse
  3. Test the thermostats
  4. Test the centrifugal switch
  5. Test the timer motor
  6. Test the heating element.
Thank you.
Posted on May 09, 2009
jumptrout51
  • 3361 Answers
SOURCE: no heat from dryer
You have a bad heating element and or a bad high limit switch. Check them for continuity with a volt meter. No continuity, replace the part.
Posted on May 24, 2009
Takes too long to dry clothes
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
The dryer is taking a lot longer to dry now than before. I'm sure it's not lint, insufficient gas supply or the vent needing cleaned. The cooling light is staying on solid and the drying light...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 06, 2011 | LG DLG2524 Gas Dryer
We have a LG dryer that is about 2-3 years old. The sensor is completely lit showing an obstruction but we have cleaned the vents out all the way to the roof and the sensor stays fully lit. The clothes...
Check the exhaust vent behind the dryer to make sure it's not kinked.
Take off the dryer vent and run the unit to see if it will dry normally. If it does, you still have a blockage in your exhaust vent in the wall.
Jul 20, 2011 | LG DLE2532W Electric Dryer
Dryer shuts off before cloths are dry,then then you have to wait about 10 mim before you can restrat dryer..cleaned vent duck to out side2 times to besure it was clean..cleaned venting back of...
Check motor for lint build up around motor. Will cause motor to overheat and shutdown on motor
overheat switch and will restart after cooling down.
Feb 11, 2011 | Dryers
We have a DLE3777W electric dryer. The check filter and cooling lights are coming on now all the time. It's drying but not as well as it has and takes longer. How do we turn off the cooling light? What...
if you pull your lint screen out and look down you will see like a metal piece with two screws, this is your sensor, more then likely it has lint/fuzz on it. I would suggest taking the cabinet(dryer) apart and cleaning it with a brush, lightly as not to damage it. Sometime you can get to it with a vacuum but if you are not careful it can be damaged. Here is a link that will help:
http://www.repairclinic.com/Dryer-Maintenance-Tips?red=Dryer-Repair-Help#areaunderlintfilter
Jan 09, 2011 | LG DLE3777 Electric Dryer
Takes 3 hours to dry a small load, dryer is 3 1/2 yrs old
You need to clean vent hose and vent line in wall of house.
May 08, 2009 | Dryers
Brown streaks
Hi thanks for the question-yes if the venting is not good ,you dryer will take 3 times as long to dry the clothes. its a must to have a clean venting. clean all venting thanks the appliance doc
May 12, 2008 | Kenmore 73952 Gas Dryer
LG Gas Stacking Dryer
The check filter light comes on every load to remind you to clean the lint filter. Cooling only happens when that light is flashing not when it's on solid. If this is a gas dryer check the exhaust hose and vent on the outside of the house. If it is blocked it will not let the unit get to the correct temp due to cycling.
Dec 16, 2007 | LG DLE2514 Electric Dryer
Clothes are taking 3 cycles to dry and cooling light on front wont shut off
The vent is clogged.  To make sure, disconnect the vent from the dryer and run the dryer normally.  If your clothes dry normally, then have a professional vent cleaning company take care of the vent.
The cooling light will always stay on during the run.  When it is blinking, the heat has stopped and is in the cooling process.
If there is no heating, you have a problem with the high limit switch or something else electrical and needs to be addressed by a qualified LG technician.
Oct 22, 2007 | LG DLE2512W Electric Dryer
LG DLG 5988 Gas Dryer Does not heat and does not dry
Same problem after 1 year of use. In the past couple of months, the Sensor and Cooling mode light stay on and unit does not dry.
Oct 08, 2007 | LG DLG5988 Gas Dryer
Dryers Logo
456 people viewed this question
Top Dryers Experts
