Question about HP Photosmart C6180 All-In-One InkJet Printer
Hp C6180 Colors don't work
I just got this Hp C6180 and some of the colors don't work. I use a Mac and can't figure out how to calibrate the colors. All the ink levels are good and none of the other solutions I've seen on this site have worked. Please help!
    President:
  • HP Master
  • 1,996 Answers
HP has an excellent online support site. Go here and look for solutions, and see this article.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 19, 2009
Self test page missing 2 colors
friend how is ur cartridges, check cartridges and check printer head
Mar 27, 2014 | HP Photosmart C6180 All-In-One InkJet...
Hp c6180 states cartridges missing or damaged
OK now this might seem bizarre, but did you go ahead and click the "Black Only" print option?
I have a C6180. Just installed all new cartridges. Tried to print and got the message that Cyan is empty. Tried all sorts of things. Then out of frustration clicked the Black Onl option. Document came out printed in color! Double checked with a picture that has lots of cyan colors. It all printed too! Go figure.
Apr 25, 2012 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 color copies (on plain paper) aren't full color
Here's the official HP solution for what you're experiencing. If you try all the steps suggested and you still have a problem, remember that you can contact HP for warranty support for the cartridges you've purchased - even if your printer is out of warranty.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00721052&cc=us&lc=en&dlc=en&product=1153494
One thing I'd try first is to print a self-test page. If you print a self-test page and the colors appear normal, you can rule out the iMac as the source of the problem.
The instructions for printing a self-test page are similar to the c7280 shown in the following video.
I am an HP employee. I do not represent HP on this site.
Jun 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
C6180 failed alignment test, will not print color properly
All colors need to be present to pass alignment. Usually what I see is the yellow is empty. You can blot the print cartridge on a damp paper towel to verify the inks are working and this also cleans the head.
Jun 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP won't print black, but other colors work. New refill kit...
I purchased a c6180 in Jan 09 have just got the black working fine. After pulling the nachine apart, thinking maybe to soak the head, found micro pump for ink air in black line Run copy black only (took maybe 12x25 times) then head clean Try head clean after 50 copies Voila! Black Cannot rule out that reseating all connections helped
Apr 21, 2009 | HP Office Equipment & Supplies
HP Photosmart C6180 colors no good - missing colors & muted. No longer aligns print when requested, per HP note at end. Already cleaned print heads,[OK], aligned printer numerous times-doesn't work....
try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Apr 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have an HP 6180 that works fine except the colors are WAY off -- everything is muted and dull and the blacks are very weak. I've tried everything in the print dialogue box -- switching to application...
Bugger! HP wants your printer to work, so you buy more ink! Mine works beautiful
Scan a good photo and print it out or insert SD card and print photo on PHOTO paper GLOSSY SIDE DOWN Inkypete
Apr 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
My hp c6180 has stopped printing in color
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
How do I scan a 35mm film negative with my HP PhotoSmart C6180?
I regret to inform that hp Photosmart C6180 does not support scanning negatives.
Regards,
Sagarjd
Nov 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One Is printing All Documnets Faded Colors
Try to clean your printheads or check the level of your inks, maybe you are low on inks. Operating system does not affect any printing outputs as I know. Check your inks also coz HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges.
If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
Replace any empty print cartridges. To check ink levels, follow the steps below.
  1. Press the Setup button.
  2. Press the down arrow button until Tools is highlighted.
  3. Press OK .
  4. The Display Ink Gauge selection should be highlighted. Press OK and the ink gauge will display.
OR try calibrate the color:
  1. Open the printer Toolbox :
  • Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
  • If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
  • Click Settings .
  • Click Print Settings .
  • Click Printer Toolbox .
2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
If the steps above did not help, clean the print head.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Please let me know if these steps helped you or not. Thanks
Jan 02, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
122 people viewed this question
Seeker5211
Seeker5211
