Question about GE Used JES1453SR1SS 1.4 cu. ft. 1600 Watt Countertop Microwave Oven
Jes1453sr1ss am/pm button will not work - GE Used JES1453SR1SS 1.4 cu. ft. 1600 Watt Countertop Microwave Oven
How do you set the clock?
using the clock button and then numbers . some have an AM/PM button that needs used also .
Oct 02, 2016 | Microwave Ovens
Clock not working how do I reset it?
If rest of controls work here is how to set clock. Press clock button, enter correct time, It may ask for AM or PM and tell you to press a button to select. Then press either start or clock again. It may actually tell you which one to press to finish Depends on which model you have.
Mar 31, 2015 | GE Microwave Ovens
Forgot how to set correct time
Push clock button. Put in numerical time. Push am/pm. Push clock button.
Nov 04, 2014 | Microwave Ovens
WOULD LIKE TO KNOW HOW TO SET THE CLOCK
Push the button that says clock, then set the time you want am or pm, then hit the clock button again so it can start working. Unless yours is extremely different, this works on most all microwave.
Sep 21, 2011 | Microwave Ovens
Error code -SE-
Hi maaki41,
The error code SE stands for a keypad is held down for longer than 10 seconds. If you were not holding down a button then you have a defective key pad because of the sensor error. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
May 17, 2011 | Maytag Over-the-Range Microwave
My microwave clock is set in 24 hour mode and I don't know how to change it to the 12 hour mode
Depending on the brand, if you push the clock button more than once it changes from am to pm to military time (24 hour) to am, to pm, etc.
Mar 13, 2009 | Microwave Ovens
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
SETTING THE CLOCK
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
You can actually download your owner's manual here
Mar 10, 2008 | Microwave Ovens
GE Used JES1453SR1SS 1.4 cu. ft. 1600 Watt Countertop Microwave Oven Logo
20 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
