Question about Nikon COOLPIX L2 Digital Camera
Camera turns on then says lens error - Nikon COOLPIX L2 Digital Camera
Every time I turn on the camera it sais Error 99 could anyone explain it to me .thanks chris
According to ehow:
Turn off your camera and remove the memory card, lens, battery and time/date secondary battery. The secondary battery is a small, round battery about the size of a dime found in the same compartment as the main battery. It is located in a vertical slot. Slide out the secondary battery by pressing your finger on the battery and pulling it toward you.
  • Place the body cap on your camera to keep dust out. Attach the front and back lens caps on your lens to prevent scratches and other damage.
  • Let the camera sit for 20 minutes. This will clear the camera's memory.
  • Place the date/time secondary battery and a fully charged primary battery in the camera and turn it on.
  • Press the shutter release button (the button you push to take a picture). If you are still receiving an Error 99, the problem is most likely caused by the camera body itself. The camera body must be serviced by a professional camera technician.
  • 6 Turn off the camera and insert the memory card. Turn the camera back on and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the memory card. Turn off your camera and insert a different memory card. Turn the camera back on and press the shutter release again.
  • Turn off the camera and reattach the lens. Turn on the camera and press the shutter release button. If you receive an Error 99, turn the camera off and remove the lens.
  • Turn the camera so that it is face down, and gently clean the lens contacts on the camera body with a number 2 pencil eraser or soft cloth. The lens contacts are the eight small, gold pieces on the bottom of the lens mount. Be careful not to let any of the eraser scraps fall into the camera body.
  • Turn the lens so that the side that attaches to the camera is upside down. Use the eraser or soft cloth to clean the lens contacts on the lens, being careful not to let any eraser scraps fall into the lens.
  • Reattach the lens to the camera. Turn on the camera and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the lens. Take the lens to a professional camera technician for repair.
  • May 11, 2011 | Cameras
    Lens error.....restart camera. Tried over and over again. Nothing works. HELP!
    Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
    I figured sand got stuck within the lens, so I did the following:
    1. Turn camera up-side-down (with lens facing down)
    2. Gently tap the sides of the camera (to loosen particles in lens)
    3. Turn camera on
    4. The lens will eventually come out
    5. Gently tap the sides of the lens
    6. Turn camera off (continue tapping side of lens as it retracts)
    I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
    Now the camera works...thank god....
    thanks.
    Apr 11, 2011 | Canon PowerShot SX10 IS Digital Camera
    1 MSG WHEN POWER IS TURNED ON 2 LENS ERROR -
    Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
    Jan 09, 2011 | Canon PowerShot A710 IS Digital Camera
    Nikon S220. Lens error. Turns on but displays lens error only.. Cannot take pics
    The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
    http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
    May 15, 2010 | Nikon Coolpix 2200 Digital Camera
    Canon PowerShot SX 100 IS lens error
    Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
    Jun 14, 2009 | Canon PowerShot SX100 IS Digital Camera
    My EX-S5 says lense error
    Jun 10, 2009 | Casio Exilim EX-S600 Digital Camera
    Lens error, restart camera
    Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
    Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
    More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
    Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
    "Lens Error, Restart Camera" Lens stuck open, completely disfunctional! /sadface :(
    Apr 17, 2009 | Canon PowerShot A630 Digital Camera
    Lens error code 111,0,0,0,
    This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
    Aug 13, 2008 | Kodak EasyShare C633 Digital Camera
    Lens error
    wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
    Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
    Nikon COOLPIX L2 Digital Camera Logo
    60 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
