Question about Onkyo Tx 2100 Stereo Receiver
When i turn the unit on,it reads protect and shuts itself off,why
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Blown fuse
Posted on Apr 18, 2014
HT4500 'Protection' error code appear after its turned on & turns itself
U have a serious problem and the unit is shutting down to protect itself against further damage. Check the power supply and power output stages for bad parts responsible for the condition.
Jul 31, 2015 | Audio Players & Recorders
No heat and turns itself off after 4 secs
1)Turning itself off can be as a result of the sensor getting feedback of not enough ventilation.Ensure unit is able to breathe by bringing it away from the wall to allow airflow. If that doesn't fix it THEN>>>>>
2) The Magnatron which is the heart of the unit is damaged and so the sensor reads overload and shuts down as a protection against fire.
Repair of the magnatron often exceeds the value of the machine and in your case is not worth repairing. You can buy used ones and refurbished trade ins cheaper than your repair costs will be
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 13, 2009 | Panasonic Microwave Ovens
Hello Protection Samsung HT-DS900
When your home theater's display reads PROTECTION, it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jun 14, 2009 | Samsung HT-DS400 System
GE Spacemaker XL 1800 Micro - " Turns itself off after 2 sec. "
It looks like a component is short-circuited and then it acts to protect. Call a service.
Sep 21, 2017 | GE XL1800 1100 Watts Microwave Oven
Unit shuts itself off after 10 -15 minutes
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Jan 08, 2009 | Samsung HT-WX70 Theater System
TV turns off after being on for just
I have the same problem and I believe the new problem is the cooling fan is not working properly and the unit is shutting down to protect itself from the heat.
Dec 16, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Toshiba home theater SD-KT50SU shuts off "PROTECTION"
Ok what this means is that some wires are touching in the back of unit causing a short (your system is protecting itself) look for wires touching and make sure its hooked up right
This should fix ya!
Dec 13, 2008 | Sharp XLDV60H Shelf System
My kenwood amplifier suddenly off when i turn the volume high?
You need to make sure you ohms are correct if there too low this will happen to protect the amp.
Dec 03, 2008 | Kenwood KR-V7080 Receiver
Sony SLV-272UC VCR player It shuts itself off in 2-5 seconds
Is there a VCR tape inside the unit? If there is a mechanical issue may cause your unit to auto protect and shut down.
Oct 01, 2008 | Televison & Video
Shuts off
The unit is protecting itself from a high current situation on the output amps. Either you have a bad speaker or an Amp that is getting ready to give up the ghost. Check your speakers with an Ohm-meter for proper readings (ie 4Ohm speaker should read 4 ohms)
Nov 21, 2007 | Kenwood VR-405 Receiver
Onkyo Tx 2100 Stereo Receiver Logo
42 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
