Question about Refrigerators
Changing light bulb in hoover contour fridge - Refrigerators
5 Suggested Answers
  • 363 Answers
SOURCE: which light bulb can I use Hoover Contour
Use a refrigerator rated bulb. If you go to a Harry's Homeower store look in the bulb section or in the appliance section take to old bulb with you to compare.
Posted on Jul 31, 2009
woodchuck789
  • 4070 Answers
SOURCE: hoover contour fridge leaking
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 30, 2009
Testimonial: "thanks, all fixed!!"
SOURCE: Hoover Contour HE423UFL fridge freezer continually frosts over?
I am on my fourth timer for this problem. Seems to fix the problem each time. You must remove the big chunk of ice covering the drain hole before you operate the fridge with the new timer. The contacts in the timer get burnt due to arcing inside the switch. The heating element seems to always work ok, but if the element is no good the fridge will not defrost.
Posted on May 11, 2010
imufo2
  • 3773 Answers
SOURCE: how to get at the drain tube of hoover contour
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
For more of my tips GO HERE:
https://www.fixya.com/SSL/myprofile.aspx#my-tips#my-tips
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Oct 06, 2011
I have a Hoover Contour HE430TF fridge leaking water to the bottom of the crisper. There is no internal drain hole. Hoover has no record of a 20 yr old model & is no help. How can I fix the problem?
it's not leaking water.. it's condensation running down the back of the fridge.. normally this is channelled into a hole that has a tube on it, that allows the water to go to a drip tray on top of the (warm) compressor, which then evaporates it.. Please re-check for a "V" shape moulding on the back if the fridge.. there SHOULD be a hole smack bang in the middle, which may have clogged up in the pipe with gunk, causing water to refreeze and block the hole completely.. best to do a full empty and clean, and use a chopstick, or better still a cheap pipe-brush from the £ shop, to clear that tube (about 1/2 inch diameter, or maybe less.)
Apr 24, 2017 | Hoover Refrigerators
How to replace light in a Hoover D42UF fridge/freezer
go to local service center & collect 15w bulb.
May 30, 2012 | Refrigerators
How do I change the light bulb in a Hoover contour HE 365UF. I can't see how to take the cover off at the back of the fridge
To change the light bulb, you need to unhook the bulbous plastic cover at the top back of the fridge. You'll notice it has two oval holes on the sides. On both the left and right, place your fingers on the vertical strips of the cover directly behind these oval holes, and press inward to release the catch. At the same time, pull down and the back of the cover will swing down, revealing the light bulb.
Oct 04, 2010 | Refrigerators
Hoover Contour HE505UF Refridgerator has stopped working light works have taken off the back pannel fan not working could it be the module on the compressor? rather not spend hundreds on it to fix would...
Same thing happened after a storm to ours. On the back of the fridge next to the motor to the left (you have to remove the panel) there was a red dial inserted. We turned it and the fridge worked again. (well one day so far).
Aug 15, 2010 | Refrigerators
Jan 31, 2010 | Refrigerators
A corner of the door has broken off and the door has dropped. The model is HE505UF hoover frost free contour fridge, can it be fixed or do i have to replace it
sounds crazy but u may be able to take a 1 1/2 " x 8" piece of flat metal bend at 90 degree angle. drill appropriate hole for hinge and screw to door. i've done it and it works.
Jan 21, 2010 | Hoover Refrigerators
Which light bulb can I use Hoover Contour upside-down fridge 505 L? Tks
Jul 22, 2009 | Refrigerators
How to replace 1998 Ford Contour headlights (with diagram)
Step 1
Remove your Contour's front grille. You can do this by raising the hood and removing two screws that are located on top of the grille.
Step 2 Remove the headlight assembly. The headlight assembly is held into the front of your Contour by three screws. Two screws will be located on top of the assembly, and one on the bottom.
Step 3 Replace the headlight assembly, if necessary. If you are only changing individual bulbs, make sure you replace the correct bulbs. Each assembly holds three light bulbs, including the bright, dim and turn signal bulbs.
Step4 Replace the headlight assembly and reattach the three screws to hold it in place.
Step5 Replace the front grille of your Contour and the two screws that hold it onto the front of the car.
  • It is usually a good idea to replace bulbs together (in pairs). This will allow the bulbs to wear at the same rate.
  • If you choose to replace only the individual light bulbs, do not touch the new light bulbs. The contact of your skin on the bulbs will cause the light bulbs to burn out much sooner.
Let me know if you have any further questions.
Benjamin
Apr 26, 2009 | 1998 Ford Contour
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
