Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Dishwasher not working
This is an old maytag about 15 years built in with mechanical dial to operate. when I try to start it the machine hums but does not start and the spray arm and pump usually start to clear out leftover water.
SOURCE: maytag dishwasher mdb9600awb - loud pump
This has happened a few times to me as well.(VERY VERY LOUD NOISE AT THE BOTTOM)I have the same model It did stop.I did a little reading and came to the conclusion that it was the built in food disposer chopping blades were chopping up something like a cherry pit or peach pit and once an end of a wooden spoon that dropped down.If you look at your USE and care Guide on page 12 under trouble shooting "Dishwasher seems noisy"..I went through the same thing taking things apart.Its got to be it. Mine is 2 1/2 years as well. Hope this helps. ronkeachie@rogers.com
Posted on Oct 06, 2007
  • 5 Answers
SOURCE: No water running to dishwasher
I had this problem and almost tossed this thing out the window. The water stopped pumping into the washer but the cycles kept on going... HERES HOW YOU FIX IT!! In the front bottom right you see the mushroom shaped float..... on the underside of the dishwasher you see that is pushing down on a switch. Its a simple little switch but the plastic pin connected to the float is easy to knock off the switch witch always leaves it in the up position !!! this is telling the washing machine that it is full of water. Find a way to keep the plastic pin on top of the metal switch and this will fix your problem. I used tape with a small piece of paper to keep from sticking to the pine or switch!!
Posted on Aug 28, 2008
rylee_smith
  • 8619 Answers
SOURCE: dishwasher suddenly doesn't clean well-doesn't empty soap disp
Hi
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Posted on Mar 25, 2009
honeymokey
  • 3113 Answers
SOURCE: Maytag dishwasher.Loud humming noise, wash cyle,at beginning
Is the water filling up and then draining out? Mine did this and a part was broken inside the unit. The part was five dollars and called a lifter. I fixed it myself.
Posted on Apr 08, 2009
MNfisherman
  • 11896 Answers
SOURCE: Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Posted on Jun 01, 2009
Water has stopped coming into the dishwasher
water inlet valve bad try shutting off water supply under cabinet then turning it back on to see if water starts working if not
Mar 16, 2015 | Samsung DW80F600UTS 24" Stainless Steel...
20 year old Maytag jetclean model WU482 small hole in front bottom of tub leaks water
At 20 appliance years of age, your Maytag may start leaking like a sieve but you can try patching the hole you see and hoping for another 20 years.
Jun 19, 2017 | Dishwashers
My Maytag dishwaher is three years old. It will not start. The only button that will work is the cycle slection.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MDBH945AWW&siteCd=MT_EN_US&userType=Servicer
Above is your link for your manuals, use these along with the DIY self help repair website below, to troubleshoot and hopefully repair the problem.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Now this fix below may not work, but it is always worth a try, if it fits the criteria. Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Jul 05, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
We got our maytag 300 quiet series about 3 years ago from home depot. about a year ago the option buttons/lights on the right side went dead. It was out of warranty and still worked so i ignored it. Now...
Our Maytag dishwasher (an earlier model) quit too. Found that the door latch operates two micro-switches which supply power to the machine and one of the switches no longer made contact when operated. The switch pair and the plastic latch parts are sold as a package for about $15 on the internet. A number of lights in the door are held in place by a small colored lens for each light and the lenses have disintegrated leaving the lights to hang by the wires inside the door cavity. Plan to use contact cement to glue the lights in place. I don't know if this will help you, but it doesn't take long to open the door cavity. Make sure to remove power to the machine before opening it up.
Feb 05, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
The dishwasher is probably 12-15 years old. It
Adjust the door lock. Check the door switch wires. Replace the door switch mechanism. In this order.
Oct 06, 2009 | Maytag Dishwashers
Maytag will not start, has power and control panel running fine
Do you ever clean it with a dishwasher cleaning agent and run it on any wash mode?
Mar 08, 2017 | Maytag MDB9600A Jetclean II Built-in...
Dishwasher just hums, faintly, when I turn it on.
motor is locked up.. if you let it hum faintly for a couple min it will cut out most likely.. thats the thermal trip built into the motor.. the motor assm needs to be replaced..
Apr 10, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Maytage dishwasher
Hi Fix it mom, If your courageous, pull the trays out of the way and remove the screen in bottom of the dishwasher to see if something is getting into the pump. By something I mean undesired matter. Straw, Twist tie, knife, toothpick, etc... I hope this helps
Sep 25, 2007 | Maytag 24 in. MDB4651A Built-in Dishwasher
It hums, but doesn't pump or wash
you may have a bad motor. I would check the float switch it is the round hat looking thing on the left side. it should move up and down easy.. you may need a repairman to change out the motor/pump..let me know thanks
Aug 25, 2007 | Maytag PDB3600A Built-in Dishwasher
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
27 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
