Question about Masterbuilt Turk-'N'-Surf's Turkey Fryer
Interpot leaking oil will not hold oil for cooking
Oils leaks after cooking
Anne, defective, seam splitting or pin hole, discontinue use, if still under warranty return for exchange.
Mar 26, 2016 | Tefal T-fal Ultimate EZ Clean Pro...
Oil leaking?
The only oil would be in the high voltage capacitor.
If that fails, either the oven will stop cooking, or the fuse will blow as soon as you press the "Start' key to begin cooking.
More likely it is grease from cooking and just needs a cleaning.
Jun 10, 2013 | Goldstar MA-780M Microwave Oven
Oil like substance
2005 sunfire burning oil and white smoke
Usually a sign of a cooked motor.
The oil can be bypassing the piston rings or leaking thru the head gasket.
White smoke is usually coolant but can be oil too.
Apr 14, 2013 | Cars & Trucks
Oil leaking from the bottom of fryer
Do you let in from hot to cold that might do something to it. Need anew one
Feb 09, 2013 | Rival CF153-WM Deep Fryer
I hit a deer and now oil is leaking out of the front of the radeator what could it be
Are you sure it's oil because your transmission cooler lines connect to the radiator so it may be transmission fluid that's leaking. I really can't see any place that oil would be in that area. good luck and I hope the deer tasted good after you cooked him.
Feb 28, 2011 | 2000 Dodge Grand Caravan
My saturn started leaking coolant, and over headting severly then oil started leaking badly...any suggestions?
The coolant leaking could be anything. The oil leaking is more than likely the result of the over heating. It would have cooked the gaskets and caused them to leak. You going to have to find the source of each and repair them. If you can locate them and need more help on the repair just let me know. Be glad to help.
Feb 03, 2011 | 1996 Saturn SW
2001 CHEVY SILVERADO 5.3 Z71 The truck uses 1 gal of antifreeze
check for a wet tailpipe,which might indicate a leak between water jacket & combustion chamber.i.e.headgasket.check heater hose isn't leaking onto exhaust manifold,'cooking' the anti-freeze as it leaks.
Oct 05, 2009 | 2001 Chevrolet Silverado
Presto fry baby
I just got one of these w/Instructions, Says fill oil to fill level line inside. Cooking oil or shortening. Never use more than (2) - 8 ounces cups of cooking oil or (1) pound of shortening. Hope this helps!
Dec 12, 2008 | Presto 05430 FryBaby Deep Fryer
Masterbuilt Turk-'N'-Surf's Turkey Fryer Logo
27 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
paulcarew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
