Best picture settings for Toshiba 32HL57
Calibration settings
  • 53 Answers
SOURCE: toshiba 32hl57 Has sound but no picture
Hello mgsystmz touch the screen of your tv set lightly look behind your finger and see if you can see light if so then the backlight is working and your inverter board is at fault, if you can not see any light behind your finger when you try the above suggestion then the backlight could be faulty and has to be replaced, both of the above circuits can cause this problem the most common problem would be the inverter board that is faulty and has to be replaced hope this helps thank you.
Posted on Aug 15, 2009
Testimonial: "I guess it's a good start."
SOURCE: My 32HL57 model tv has sound but no picture?
en francais
le modul est fixé sur l'ecran
sur ce modul verifier si vous avez 3.3 volt (trois regulatuer avec un test point) si vous n'avez pas 3.3 verifier les deux fusibles F1 et F2
F1 devrais etre ouvert ....
bonne tv ;)
module is fixed on the screen
this modul check if you have 3.3 volts (three regulatuer with a test point) if you do not have 3.3 Check both fuses F1 and F2
F1 should be open ....
good tv;)
Posted on Oct 05, 2009
  • 290 Answers
SOURCE: Best picture settings for toshiba regza 42RV500e
Go to menu on your remote control and select picture setting and try selecting "default" setting to seeif you like the color, if not adjust contrast to about two thirds of the way and brightness to your liking and color to about the middle.
Posted on Jan 17, 2010
SOURCE: I am looking for calibration
go to CNET reviews
Posted on Mar 05, 2011
SD Tech
  • 14553 Answers
SOURCE: Can't see image with shaw pvr on toshiba 32hl57
I presume you followed the instructions in the TV manual during hookup and did not hook up with the units powered up and did select the correct input with the remote?
If you have another unit that uses HDMI try a direct hookup with it to see if the HDMI input is working.
HDMI units do not like being hooked up when units involved are powered up and on--seen more than a few where this was the problem and it is worth a try if the Owner Manual does not help you.
Posted on Apr 10, 2012
How do I remove the stand from a toshiba 32hl57 tv
  • 1 & 2 Remove all cables and lay down towels on a clear space.
  • 3 Set the 32HL57, screen side down, onto the towels gently.
  • 4 Locate the four screws at the bottom center of the TV. These screws attach the stand to the Toshiba 32HL57.
  • 5 Using the Phillips screwdriver, unscrew all four screws, one at a time.
  • 6 Once the screws are completely removed, grab the base of the stand and gently pull away from the TV.
  • Read more : http://www.ehow.com/how_7318172_remove-stand-toshiba-32hl57.html
    Jan 20, 2015 | Toshiba Televison & Video
    Picture settings..? What are the best calibration
    You can't use someone else's numbers, even for the same set, and expect them to be perfect. The picture settings are governed by the viewing conditions in your TV room.
    Settings such as Brightness can only be set correctly in the room where you are viewing. Brightness affects where you might then set gamma, and contrast, and colour. So just one setting has a lot of impact on several other areas of the picture.
    Putting in someone else's numbers will make the picture look different. But that's not the same as the "best" calibration for your TV.
    If you want to do a good set-up without spending any money, have a look at your DVDs and Blu-rays for those titles with the THX Optimizer.
    Sep 13, 2014 | Televison & Video
    Apr 10, 2012 | Toshiba Televison & Video
    en francais
    bonne tv ;)
    good tv;)
    Sep 26, 2009 | Toshiba Televison & Video
    Toshiba 32hl57 Has sound but no picture on any/all inputs selected
    Aug 15, 2009 | Toshiba Televison & Video
    LCD tv main/digital board
    Send it to us and we will refurbish the board.....
    e-mail me....circuitworld@comcast.net
    Feb 11, 2009 | Toshiba 32HL67 32 in. LCD Television
    I might be able to help... Can you send me a pic of the board?
    jerry.nelson.nj@comcast.net
    Feb 11, 2009 | Toshiba Televison & Video
    Would like a free manual for a Toshiba Flat Screen Model #32HL57. lost mine. Thanks
    there is a websit retrevo.com that can help. Log in and then put the manual you need. Most of there manuals are free and downloadable. God bless you
    Jan 12, 2009 | Televison & Video
    Televison & Video Logo
    Top Televison & Video Experts
    Electro Med Services...
