Question about Dynex DX-L19-10A LCD TV
Need to turn tv to channel 3 without remote
Have no remote, but need to ensure tv is turned to channel 3 or 4, but cannot use up down buttons
2 Suggested Answers
gopakumarg43
  • 74468 Answers
SOURCE: why my remote to my dynex tv all of a sudden won't work was watching tv went to change channel and nothing put in new batteries
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing each button on it at a time; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Posted on Jun 27, 2015
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
GE Universal RC24929-B Need set-up code I want to be able to change channels from remote. Thank you
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on.
3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thanx
Aug 01, 2010 | RCA RCR450 Remote Control
Stuck on 3 channels, no remote.
U can't get to channels 3 or 4 without a remote.Ur getting stuck on these particular channels 26,35 and 19 mean the last owner put these channels on the tv memory.Try website like Remotes.com to buy an exact remote or very close to the original,if u want make use of this tv.
Jun 15, 2010 | Sylvania 6420FB 20" TV
My tv was playing fine when I turned it off. Later, I drop the remote prior to attempting to turn the tv on.Tv will not turn on with or without remote.
OK, YES you CAN turn on the TV without the remote, in fact you can do nearly everything that can be done on your remote, on the TV itself, NOW look, CAREFULLY around the edged or sides of your set, you will find there are "Buttons" usually there are 6 - 7 Buttons, if you look carefully at them you will see they are marked, usually with a Volume Up & Down, word, or symbol, A Channel Up & Down, buttons a Menu, an Enter, and an ON/OFF button, & sometimes others. Now To turn on, Press and hold the Power button, the TV will Turn ON, you can change Channels, with the Channels, and Volume, with the Volume ones. The Menu button, will allow selection to all the other sub menus and settings. IF you need to get a remote, Please, get an original, it may be more hassle, it may take longer to get, it maybe costs more... BUT IT WILL WORK. Universal remotes, well, read through a few posts dealing with them, and you will see what I mean. IF you MUST get one, absolutely ensure that it performs every function the original one did, or you can have many headaches.
Apr 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a Dynatron DYN100Z remote I need to set it for a Symphonic TV . It has worked on this TV before. I lost the code.
1. Turn your TV ON.2. Hold down "Code Search" until the red light turns on. 3. Click the (+) Channel button once each second, until the TV responds by flipping a channel. 4. One the channel changes, press the, "ENTER" button. 5. Code is saved!
Jan 07, 2010 | Televison & Video
Rca remote code for a trutech tv
Try this as all remotes work similar.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 26, 2009 | RCA 3-Device Universal Remote with...
Need code to re-set GE rc24912-e remote for a Sanyo tv.
Note:
Sep 25, 2009 | GE JASRM24912 Remote Control
Unable to find a code for an admiral tv NO.GOJ
Most universal remotes work the same. Try this.
Note:
Sep 23, 2009 | RCA 3-Device Universal Remote
Cannot find manual. need to program menu
Hi and welcome to FixYa,
The user manual for a Brookstone 538744 is available here. It is in pdf form and would need Adobe Acrobat Reader to view the file.
Good luck and thank you for using FixYa.
Jun 25, 2009 | Brookstone 538744 Remote Control
I need to manually turn the TV to ch 3 and cannot because it skips it from 4 to 2.
Enter "3" or "03" on the remote and press OK/Enter.  If the channel-skip feature is set on for Channel 3 you cannot get to it using the up/down buttons.  Go to the setup menu to disable the channel-skip for Channel 3 if you want to tune it with up/down buttons.  If you have no remote you should be able to access the menu from buttons on the front of the TV. (They may be inside a door or panel.)
May 20, 2009 | Televison & Video
Dynex DX-L19-10A LCD TV Logo
26 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
