Question about Microwave Ovens
CB-1 error code in LG Microwave - Microwave Ovens
What is error code E-10 on a LG microwave oven, model MC- 7646UQ
This usually means a defective control circuit board.
Contact manufacturer for help.
Jun 27, 2017 | LG Microwave Ovens
LG LMV1813 F4 error code
F4 means sensor open, You have to check the Humidity sensor.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 31, 2017 | LG LMV1813ST Microwave Oven
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
My LG microwave oven not working.
not to b messed with even unpluged capasator holds 10.000 volts dc if it discharges onto u it can kill b carefull
May 03, 2015 | LG Microwave Ovens
My lg fridge is giving me an error code of FF what is this mean
Your LG refrig is in Demo Mode.
1.- disconnect power supply and reconnect
If the error continue
1.- Open the door of refrig.
2.- Press button "Refrigerat" while press "Ice P" button 15 seconds
If the error continue try again
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | LG Microwave Ovens
Kennmore ultra wave shut off and F-9 message on display
LG's service manual troubleshooting section suggests the F9 code could be due to line voltage, magnetron, inverter module, "Relay 2", or a loose connection between door/magnetron/control PCB (Power Control Board).
Other indications might help narrow down these choices before having to pull out your multimeter and crack open the microwave case; for example, if the microwave works, but heats slowly, then the troubleshooting manual narrows your choices down to magnetron or line voltage problems, and pretty much rules out the other possiblities.
In other cases, F9 error code indicates an inverter failure. This can sometimes by caused by a power surge or glitch through the electrical lines. You can sometimes clear this fault by completely unplugging the microwave for 1 minute. Plug it back in and see if the fault code returns. If it does, then you have an internal component failure that will need to be serviced by a technician.
Hope this helps (remember to rate this answer).
Sep 09, 2011 | Goldstar MV-1515 Microwave Oven
Lg microwave oven mc9283jlr error=e01
My LG microwave heating is OK but the grilling only not working
Jul 06, 2009 | LG Microwave Ovens
Microwave toaster combo
F1 usually means a shorted keypad or a problem with the control circuit board. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by not using the fan when boiling on the stove top (for over the range models), direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. You may have to contact LG support to see what that error code is and to find a local servicer: http://us.lge.com/support/support.jsp
May 17, 2007 | LG LTRM1240 Microwave Oven
Microwave Ovens Logo
18 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
