Question about Cuisinart CHW-12 12-Cup Coffee Maker
Water isn't hot enough - Cuisinart CHW-12 12-Cup Coffee Maker
Blower works no heat on 1999 Ford Taurus
Check the heater hoses that go into the firewall to the heater core, they both should be hot,if only one is hot and the other isn't,then the core is plugged. Remove the hoses at the firewall, buy of hose the same diameter,buy enough length so that you can flush away from the engine compartment, install it on one of the heater core pipes,using a garden hose with a jet sprayer slowly blast water into the hose, until you see clean water coming out from the other pipe. Remove the hose and install it on the other pipe of the heater core and repeat the process,you may have to do it several times to completely unplug it. This is a typical problem with a 3.0, 2 valve taurus,coolant looks brown and rusty. The entire cooling system should be flushed, if it isn't the heater core will plug again.
Apr 07, 2012 | 1999 Ford Taurus
No hot water
sound like a problem with the pump, feel the pump when its should be runing to see if it is,there should be a nut with a slot at one end if this is turning then the pump is working if not it isn,t.if it isn,t check it out
Dec 21, 2011 | Washing Machines
I RECEIVED THIS FROM MY DAUGHTER SO HAVE NO INSTRUCTIONS BUT THE WATER ISN'T HOT ENOUGH FOR MY COFFEE
the element might of burned out. Is it a used coffee maker? Elements do burn out from time to time and you might have to just buy a new coffee maker.
Aug 16, 2011 | Vacuums
Haier MS105OS: My washing machine runs for about 4 mins and then stops, saying error 5. What is error 5 and how can i fix the problem?
For Haier machines 'error 5' means ' the required water level has not been reached within 8 minutes', or in other words it isn't filling quick enough!
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 12, 2011 | Washing Machines
Is it a cold water or hot water fill
It's your choice.There's only a single supply hose and with most dishwashers that means cold fill only, but as this is a compact basic worktop model the manual supplied suggests that users connect to a hot water supply.
In real-life situations though, the water drawn from the hot supply often isn't instantly hot so all you do is drain cold or tepid water from the supply pipe and let it get replaced with wasted hot water which then cools in the pipe! If the machine features condenser drying like many dishwashers, then cold water is essential for it to work. A final consideration is that unless your hot water is supplied at mains pressure (such as in a combi-boiler or megaflo system) then the water pressure from a hot water storage tank will not often be high enough and you'll have to use the cold supply.
Jul 13, 2011 | Bush DW5F 22 in. Dishwasher
The dishwasher is not cleaning the plates and glasses as should, leaving a lot of residue on everything
It sounds like water isn't being forced through your spray lines, which could be a result of either you trap being clogged or the sump pump not working. It could also mean that your heater element isn't heating the water hot enough for it to clean.
If it only the upper rack then it could be a blockage for the upper sprayer, but if it is throughout the machice, then it would either be the sump pump, trap or heating element as the most likely causes.
Jul 03, 2011 | Dishwashers
The water is too hot coming out of the shower and if I turn the handle it does not cool enough. It is a Moen exactemp control.
You have the scald guard set to high. Take off the handle and the face plate. You will see a small plastic half moon looking part with teeth. Yours is probably set all the way one way which keeps the cold water side restricted and the hot side fully open. Carefully pull the half moon part out and rotate in about halfway and reinstall. That will give you equal cold and hot water flow. If that isn't right for your needs, you can play with the settings.
Jun 30, 2011 | Moen & One Handle Tub & Shower Faucet
Sometimes there isn't enough hot water for a shower when the hot water mode is set.I have set the hot water temperature to 65 degrees
Are you waiting long enough for the water to be totally heated, before showering? Unfortunately, all the water doesn't reach 60 degrees celsius (140 degrees fahrenheit) in a matter of minutes. Try switching to the hot water mode sooner and allow enough time for the system to heat up entirely. If that doesn't solve the problem, the burner may need cleaning,
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
Error "HO"
If your hot water isn’t hot enough it will display “HO” while heating the water to operating temperature.
Thank You Huum
Please remember to leave a solved rating before you sign off!
Dec 20, 2008 | Dishwashers
Error code HO on frigidaire gallery series dishwasher
Sep 06, 2008 | Frigidaire Dishwashers
Cuisinart CHW-12 12-Cup Coffee Maker Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
