Question about Skil 2362 02 7.2 Volt Lithium Ion Drill/Driver
My SKIL 2362 will not work
I've had this tool for about 6 months. I've never had a problem with it until now. A friend told me I should not have left it in the charger, that it burned my battery. I went to Lowes and the salesman told me that should not have caused it to be dead. They told me to contact you. They don't know how to fix it. I don't know if the battery is the problem or not. I would hate to get a new battery and not have it work. Please advise. Judy
    Habit-Forming:
  • 75 Answers
Try the link.It's a PDF file for the tool you have.It will explain what you should do to store the tool and take care of it.Most likely the battery is no good and you will need a new one
Posted on Jun 19, 2009
I have a Skil Model 2363 drill. Used it about 3 times. Put it in the charger and it won't charge. I have it for about 1-1/2 years. Skil says I have to buy a new one. That the battery is no longer made....
Sometimes places like Batteries + and the Battery Barn (on line web sites) will have replacement batteries for popular models even after the manufactures quit producing them. That is where I found batteries for my Bosch drill.
Jun 24, 2011 | Skil 2362 02 7.2 Volt Lithium Ion...
I bought a Skil 9290-01 angle grinder and a spring that is between the on/off switch and the motor broke after about two months of use. It is a spiral spring with a semicircular loop on the end, not a...
I checked several sources and agree with you, they don't want end users to be able to repair the tool apparently. I have a toll free number for Skil that might help it is 1-877-754-5999. I also found the breakdown and they as you know don't really show any parts. They might even replace the tool for you under warranty or repair it.
Jun 19, 2011 | Skil 9290-01-RT 6 Amp 4-1/2" Angle Grinder
Drill is less than 6mo. old and won't charge
Take it back where you bought it and ask for exchange. There will not be a problem if it is that new.
Mar 08, 2011 | Skil 2362 02 7.2 Volt Lithium Ion...
Power Driver is charged - won't work
If you are sure that battery is fine, problem can be in the switch or brushes. I would check switch first - open the driver, take 2 wires and attach battery directly to motor contacts, in case it works, problem is most probably in the switch. Juraj
Jul 11, 2010 | Skil 2362-01 Factory-Reconditioned 7.2V...
Charged it and it stopped working
Here is the link to Skil. http://www.skiltools.com/en/CustomerService/ServiceCenters/
Call them and see what they recommend that you do. They will want to keep you as a valued customer. Regards, Joe
Jan 25, 2010 | Skil 2362 02 7.2 Volt Lithium Ion...
Skil charger & batteries won't charge
The only thing I suggest is taking your Skil driver to a Bosch service center (Skil is now owned by Bosch) and they will replace the charger under warranty if the driver is less than a yr old. If not those chargers are not that expensive. Either way you need a new charger because they are not repairable.
Jun 10, 2009 | Skil 2362-01 Factory-Reconditioned 7.2V...
Skil cordless drill model 2362 - won't charge
I have the same problem. The guys at Batterries Plus told me that 7.2 volt battereis are not easily replaced and definately not through them. If you left it charging for to long (ie over a week when you were gone like me) then the battery is never gonna charge again. You might as well find the same model of dril at skil's reconditioned site for around $40 or buy a brand new one for $60 or $70
Mar 30, 2009 | Skil 2362-01 Factory-Reconditioned 7.2V...
How to change drill bit on black & decker plus pivot cordless drill How to change the bit on a Skil cordless screwdriver 2362 with a keyless check?
Grab the end of the chuck in one hand, and the outer ring of the chuck nearer the motor, and twist the chuck end. try both directions until it loosens.
Jan 28, 2009 | Drills
I have a Skil 2362 7.2v drill that goes dead when charged
Sounds like the trigger switch is bad. If you know the charger is good and it is charging the battery, then it must be the switch. I suggest you take the charged battery and test it with a multimeter for the 7.2V. If the battery is dead, then check the charger.
Take it back to Lowes and get a different brand.
Jan 19, 2009 | Bosch Skil Drill / Driver Kit
Skil 2362 02 7.2 Volt Lithium Ion Drill/Driver Logo
640 people viewed this question
Top Skil Drills Experts
epangan29
 steve
steve
Are you a Skil Drill Expert? Answer questions, earn points and help others
