Question about Bowflex Treadclimber
Error H 05 - Bowflex Treadclimber
I get a error 05 code on my precor treadmill C932/C964
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Apr 05, 2014 | Precor 932i Treadmill
Corrective Action
Error 5 stuck key
Precor Error 05, Key Depressed at Power Up Probable Cause: 1. A key is permanently depressed on the display.
Corrective Action
Feb 17, 2014 | Precor EFX 556 Elliptical
ER 05 displayed on precor 9.31?
Corrective Action
Nov 23, 2013 | Precor Exercise & Fitness
Precor EFX 546 05 stuck key
Corrective Action
Jul 02, 2013 | Precor EFX 546i Elliptical Version 4
Key depressed error
Corrective Action
Nov 13, 2012 | Precor EFX 546i Elliptical Version 4
Error code 05 appeared on screen. We have tried to reset. Hit stop, enter, & quickstart buttons as decscribed. We also tried the reset button. The error code remains. We unplugged and tried again, but...
Corrective Action
Apr 11, 2011 | Precor 933 Premium Series Treadmill
Error code 5
Corrective Action
Aug 11, 2010 | Precor EFX 546i Elliptical Version 4
Iomega HDD Fatal Error 05
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Jul 05, 2009 | Iomega ScreenPlay
The port the modem is attached to could not be opened; Opening the modem device failed with error 000005aa
Sounds like a hardware problem
First > try changing the modem port (default is com3, try changing it to com4 or com5 whichever is free)
Try querying the modem again
Second > Contact your modem manufacturer
May 26, 2008 | Conexant chipset 56K V.92 PCI Data/Fax...
Bowflex Treadclimber Logo
18 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
