Question about JVC HARX700 Headphones
What kind of adapter to connect to tv - JVC HARX700 Headphones
Hi kindly help me connect led LG Tv output system to a mini hifi MHC-GNZ55D system so as to have powerful sound from TV?
The head unit doesn't have an audio input on it... you could use a tape deck to 1/8" and connect that via 1/8" female to 1/8" female adapter and an 1/8" to stereo cable to connect it to the TV but there will be a level of noise associated with this option due to the components. You could also use an FM transmitter plugged into the 1/8" female adapter.
Apr 11, 2016 | Sony Audio Players & Recorders
Do i need a s cord for sound when hooking up dvd player to tv
  • The connection you choose depends on the kind of connections available on your TV and on your DVD player. Some manufacturers provide only one kind of connection, others two kinds, and still others all three.
  • Regular AV connections provide good video quality.
  • S-Video provides better video quality.
  • Component Video provides the best quality video next to HDMI.
  • HDMI connections are the highest quality connections If need be adapters are available, to switch from S video cable to what you want. Check the attached links,instruction and guides, Good luck.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How Do Connect My DVD Player To My TV
How to Hook Up DVD Player
Video Adapters
Mar 26, 2016 | Audio Players & Recorders
On my Vizio TV, the video input connection is to big for the Plug. Is this a defect or do I need some type of adapter?????
That is A HDMI Port Not a common USB Port, You have to have a computer that is Compatible with that.
Oct 08, 2013 | Dell Dimension 2400 PC Desktop
I bought speaker that are supposed to connect to the tv Cineblue speakers wireless 2.1speaker system with subwoofer and tv RCA P61939 61 in. Rear Projection Television where do I plug the cord that...
I can find not much on the Cineblue speakers. What kind of cable does it use to connect? Is it a stereo sub mini plug? If so, you may need an adapter to connect it to the Audio outputs on the back of this particular set. Here is my first suggestion.That is the simple solution. there are many other types of cables/adapter boxes that will solve this issue.
Jul 21, 2013 | Audio Players & Recorders
Connection
Try going to the shops where they sell these kind of things and see what they say
Apr 22, 2012 | TP-LINK Computers & Internet
I want to purchase the 28 inch TV - however when I reviewed the literature I couldn't figure out if our sound bar (Samsung model # HW-C451) would hook up to it - we only have a fiber optic connection...
Well before I can tell you if there is an adapter available, you need to tell me what kind sound outputs are available on your tv. Please provide this info so that I can tell you whether there is an adapter available.
Mar 27, 2011 | Hannspree 28" Widescreen Flat-Panel LCD HD...
I'm trying to plug my laptop into a tv to display my desktop and I can't seem to do it. I got a vga adapter and cord that is plugged into both the tv and laptop. What am I doing wrong?
The 13" White MacBook 2.0GHz has a mini-DVI out port. The adapter you need is
Apple Mini DVI to VGA Adapter
On the TV side, more information is needed. You need to specify what ports on the TV you are using for your signal, and what kind of adapter cable you are using. I suspect this is the component or connection where your problem lies.
May 20, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Would like to connect Bose Acoustic Wave II sustem
If your TV have audio output ( RCA or any kind ) then you can hook that up ( you can buy the cable from radio shack ) then to BOSE audio input w/c is the AUX input.
Apr 26, 2010 | Bose Wave Radio
XBox360 connection
i dont think there is an adapter available 4 that and im pretty sure wireless isnt an option if ur trying 2 connect it 2 ur tv. although u can go wireless 2 ur router 4 xbox live.
Apr 01, 2008 | Microsoft Xbox 360 Console
JVC HARX700 Headphones Logo
26 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
