Question about Presto 05420 FryDaddy Deep Fryer
What happens when you do use an extension cord with a fry daddy
The plug on my Toro power blower vac got super hot and melted the inside of the extension cord plug. what happened?
It appears that for some reason, the connection at the extension cord, overheated. Could be caused by: 1. a problem with the vacuum unit (bearings, jamming up, something like that)
2. The extension cord itself was defective. Could have been abused, moisture could have broken down the "contact" or the point of contact or blades of the extension were loose and caused excessive current draw at that point, overheating the device.
Or, it could have been a factory fault with the extension.
Plug your blower into a good receptacle, and see how it runs. If it is
sluggish or not coming up to speed, the problem could be in the unit.
Check manufacturer's recommendation for extension cord size and length.
Dec 02, 2016 | Toro Garden
Sony home theatre system
Good enws is yout unit is not fried. Bad news is you need to get the protection fuse replaced...
Mar 04, 2008 | Audio Players & Recorders
A power surge fried my Epson Home Lite projector HDMI port......how much does it cost to repair or is it pretty easy to buy the part & fix yourself?
I have lost many things to power surges; sometimes it's only the electric cord (can be replaced), sometimes it's the battery (for lap tops), sometimes it's the electrical socket itself (try plugging into a different one). Worst case scenario the whole thing is fried (not all power surges are equal) now that I have everything plugged into surge protectors I only see them fry (beats losing another computer) try plugging it in without the surge protector or extension cord (if you were using one).
Oct 17, 2013 | Video Game Consoles & Games
Where are the fuses in my microwave oven,?
Inside behind the display panel on a small circuit board.
Jan 01, 2013 | Magic Chef MCO160UB Microwave Oven
I lost the cord to my fry daddy and need another one
Believe it or not, a lot of appliance cords will fit into other appliances. That is especially true of the cords with just the two holes to plug in to the appliances. I also lost mine, but found that a cord works great.
Sep 08, 2011 | Rival CZF630 Deep Fryer
BRAND NEW COMFORT ZONE HEATER MELTED MY EXTENSION CORD IT WAS ON 1500WATTS I DO NOT KNOW WHY THIS HAPPEN, WHAT CAN I DO TO PREVENT THIS FROM HAPPENING OR WORSE CAUSE A FIRE, I AM SCARED TO USE IT NOW
1500 watts is about as strong as the extension cord can handle my advice would be to buy a heavy duty extension cord made for a/c or heaters which are alot thicker than an average cord and only have a single plug on the end.
Dec 30, 2010 | Heating & Cooling
My A.C doesn't turn on
cause don't use an extension cord. probably fried the gfi or burnt other wires if you have a meter just test it
Jun 05, 2010 | LG LB8000ER Air Conditioner
Refirgerator was connected to regular wall outlet and stopped working, was using 14 guage 15 foot extension cord--is this risky?
Yes it is risky and you can fry the compressor because of the voltage drops in the house wiring and extension cord. If it clicked a lot that is most likely what happened.
Nov 30, 2009 | Frigidaire 16.5 Cu. Ft. Top-Mount...
I need to purchase a fry baby
The fry baby is no longer manufactured. The smalles deep fryer is the fry daddy.
Aug 07, 2009 | Presto 05430 FryBaby Deep Fryer
Presto 05420 FryDaddy Deep Fryer Logo
67 people viewed this question
Top Presto Kitchen Appliances - Others Experts
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Presto Kitchen Appliances - Other Expert? Answer questions, earn points and help others
