Question about eMachines ET1161-05 PC Desktop
Where is video card located
No signal to monitor could it be video card? if so where is it located? thanks
My monitor says :"No signal" What is the problem?
To help you troubleshoot the monitor 'No Signal' issue, please find the steps given below:
- Turn off your computer.
- Unplug the cable running from your monitor to your PC and plug it back in, making sure the connection is firm. The most common cause of this error is a loose cable.
- Re-attach the cable running from your monitor to your PC. If the monitor is still not displaying a signal after firmly reattaching the cable, the problem could lie with the cable, especially if the cable has visible damage.
- Replace your monitor with another monitor if possible. If the 'No Signal' error still appears, the problem does not rest with the cables or the monitor, but with your PC.
- Open your PC case and locate your video card. Remove the card and then replace it firmly in its slot or, if possible, insert the video card into another slot on your motherboard. A video card that is not making a firm connection will not display images to the monitor. Close your PC case and test the monitor again.
- Replace your video card completely. Your video card may suffer from internal damage that is not allowing it to output a signal.
If issue persists, it is recommended to contact your monitor manufacturer for further assistance.
GuruAid.com
Jun 13, 2016 | AG Neovo SX-17P SX-17P 17" LCD Monitor 3...
MSI Video Adapter Cause Blank Monitor
From a cold boot- go into safe-mode. Install the drivers for the MSI video card and do a warm boot.
Mar 07, 2014 | MSI Computers & Internet
New display detected vista
Boot-up in safe mode; add the MSI video drivers and re-boot normally
Video signal absent
This sounds as if your video card is not seated. Your vidoe card is where the monitor connect to the tower. If you can open the tower locate the video card and check to see that it is seated in the slot firmly. Mkae sure to diconnect the power supply before opening the tower.
Aug 20, 2012 | Computers & Internet
What does dvi mean
Hello figment_of_u,
DVI stands for Digital Video Interface. They are used for direct digital connections between source video (namely, video cards) and LCD monitors. This provides a faster, higher-quality image than with analog, due to the nature of the digital format. All video cards initially produce a digital video signal, which is converted into analog at the VGA output. The analog signal travels to the monitor and is re-converted to a digital signal. DVI-D eliminates the analog conversion process and improves the connection between source and display.
Hope this helps you understand what DVI is for. Thank you for choosing Fixya.
Feb 12, 2012 | HP 2009M Monitor
Hyundai U220WD LCD monitor displays OFF MODE (on a black backgroung). How do I restore the display? What does the MWE button do?
Hi
If the screen is connected to a computer usually its a video card/ video cable problem and not the LCD monitor. Try to check the video cable look for loose connection or bent pins, if none try using a different video cable or checked the video card component of the computer too see if its still working,. Your monitor is dependent to your video card signal inside the computer. Without the signal monitor will not work.
thanks for using Fixya
Mar 25, 2011 | Hyundai Electronics N220W 22 inch LCD...
Get a no vga signal on my monitor, then screen is blank what could it be ? thanks
The monitor is not detecting a signal from your video output.
The video circuit may be blown. If it is a plug in card, try re-seating the card in the slot. Make sure your cable is seated good and there are no problems with it. If you have another monitor, you might try it. If the video circuit is part of the mother board you may have to get a new one. If not on maintenance, you could try buying a plug in video card. May have to reset your BIOS settings to let the system know you are switching to a plug in card. Also, your monitor could be having a problem.
Dec 23, 2009 | CTX P772 17" LCD Monitor
Replacing old crt monitor with lcdmonitor
you will need to update a new driver for the monitor
if it's too old you will need a new video card thats compatible with the new monitor.Which i think your brtter off doing.
please don't forget to rate me
thanx
Jan 31, 2009 | Computers & Internet
Conver the signal of old CRT to VGA signal.
we use the old CRT monitor made by motorola with TTL video signal and different vertical &horizontal frequency signals than monitor with vga signal.at now we can not replace crt with lcd .is there any interface to convert this crt signal to vga monitor signal for replacing the crt with lcd or vga monitor ,beacause this crt is discontinued and the quality of video is weak.if you needs the crt specification i will post it for you.thanks.
Jan 30, 2009 | Computers & Internet
LG StudioWorks 700s Monitor NO SIGNAL
First of all I would check your video card. Do you have another monitor that works fine? If so I would hook the good monitor to your video card and see if you are getting a signal. If you still do not have a signal in the good monitor there is something wrong with your connection on your video card. Check the connector on your video card if it wiggles alot then it has come loose from the card. Best option here is to buy a new video card. If you feel that the connector is seated flush and does not move. Then you might want to look at two things. Either your monitor is not working properly or there maybe a piece of hardware that has come loose or unseated in your computer case. Try this and if you have problems feel free to contact me.
Sep 20, 2007 | LG Studioworks 700S 17" CRT Monitor
eMachines ET1161-05 PC Desktop Logo
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
