Question about ASUS Ve Ve208 20" Widescreen Lcd Monitor - Black
Screen is fuzzy
Half of the screen is fuzzy how can i fix it
Half screen
Sounds like a faulty screen, has the laptop been dropped or physically damaged? can you only see half of the screen? if the other half is black and one half "fuzzy" it's most likely that the liquid crystal display has been cracked/broken. The only way to resolve this problem is usually by replacing the screen which in some cases can be as expensive as a new computer :(
Apr 28, 2013 | eMachines Computers & Internet
Have a block across the top fifth of the screen that is just dark black lines, and the rest of the top half has some kind of fuzzy interference. The bottom half of the picture is fine.
bad upper Y buffer board
you will need to replace this part to fix the issue.
it is usually called a y driver or y buffer
look on www.shopjimmy.com
or www.partsearch.com
Sep 09, 2010 | Samsung HP-T4264 42 in. Plasma HDTV
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
LG Plasma screen just went nuts
It could be any of 4 boards, either take it in for service or get a new set.
Nov 16, 2017 | LG 42PC3D 42 in. Plasma Television
Screen gets fuzzy and freezes
i found that pushing down on the left of the screen (bottom if its opened) will stop it from doing that for the most part, my phone does it too, probably a loose internal connection, or at least it was, untill it stopped turning on completley...
Jan 28, 2010 | Samsung Gravity SGH-T459 Cell Phone
TV shows on half screen. other half fuzzy
You have some cold solder joints on the PC board. Flux and re-flow all of the electrolytic capacitors connections..
Aug 29, 2009 | Televison & Video
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Half fuzzy screen
you have too get a wet tissue and put soap on it if you do that it will get fixed.
- Psp master
Dec 24, 2007 | Sony PlayStation Portable (PSP) Console
My "42" inch sansui plasma monitor
You don't have any magnet anywhere near the TV do you ?
If not it sounds like something magnetic is interferring with the picture.
If not get the warranty out :D
Dec 16, 2007 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
ASUS Ve Ve208 20" Widescreen Lcd Monitor - Black Logo
13 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
