Question about Mitsubishi Televison & Video
How do you tell when the color wheel is going bad
Have a dlp tv it starts just fine after 15 or so mi nutes the picture starts to flicker and you hear a noise coming from the back of the tv
  • 1153 Answers
SOURCE: Picture flicker
You can get info at ctechnicians.com
Posted on Dec 22, 2007
  • 208 Answers
SOURCE: Color is bad after installing color wheel in samsung dlp tv
Most times color does not to be reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has be replaced with a new airless bering color wheel.
Posted on Apr 07, 2008
  • 63 Answers
SOURCE: Picture Problem!!!!
Sounds like the backlight isn't working.
Can you see a very faint picture? It might be so faint that you can only see it in certain lighting conditions.
Backlight problems are usualy caused by a faulty inverter board. I think you'll need to contact Dell as they can be funny about supplying spare parts.
If you can get a picture of the inverter board and post it, I might be able to locate a pattern board for you. The Inverter board has several flat transformers on it.
Be carefull, that board has some high voltages on it. Dont plug the set in while you have the back off.
Hope this helps
Andy
Posted on Jun 25, 2008
SOURCE: Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Posted on Sep 26, 2008
  • 3 Answers
SOURCE: COLOR WHEEL
Call Vance Baldwin.
They are on the net.
Posted on Oct 29, 2008
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
I have a Vivitek RP51HD41-A TV. The TV keeps turning off and on. The color and sound is fine. I have replaced the lamp and this has not fixed the problem.
If its a DLP it may have a color wheel which could be your problem (the colors will change etc)
Color wheels move at high speed and if slow down set will shut down.
The wheel if there will face the lamp. If often if failing will make a high pitched whine or a fan like sound.
May 29, 2012 | Vivitek V37655 56" DLP TV
I have a 50" Phillips
Check ur owner manual or call Philip support Tech. ask it this tv model have a colors wheel design into it tv.Not sure for a Philip model tv 50" DLP tv,but the Samsung model 50" DLP tv this problems alway causes by a dying colors wheel that design into it tv.Which the colors wheel it is warp worn out and spinning off of it motor mount axis to cause grinding noises and tv colors to mess up and flashes or have flashes Black & White within it picture.
Jun 07, 2011 | Philips 50PL9126D/37B 50" DLP TV
My samsung dlp lost it's color and the picture is flickering and breaking up sound is fine It's also making a louder humming sound than usual. what is the problem
It sounds like the color wheel has failed and will need to be replaced. Color wheel will cost around $175.00-$200.00 plus 1-1.5 hours labor. You can call 1-800-samsung for the nearest service center.
Aug 06, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung HLP5085W DLP - lamp replaced about 7 months ago. I powered up TV and got strange colors with flickering picture. Turned unit off and triangle symbol appears with lamp showing - needs replacement....
Strange colors and flickering picture symptom shows problem with color wheel and/or dmd board.
Lamp is only light source in dlp tv and it has nothing with colors or picture flicker.
TV goes to protection mode because of some internal problem as mentioned above.
If you wish to repair tv by yourself then you should have service manual copy in hand and that can be downloaded from HERE for small fee.
Hope these info will help you.
Thanks.
Jul 04, 2010 | Samsung HLP5085W 50" Rear Projection...
TV worksfine for one hour, colors fade in and out, flickers
Color Wheel, Go website Encmpass Parts Distr Look up the part # if they do not have it in stock then go to E-Bay look under Electronic 1-800-638-3328
Oct 07, 2009 | RCA HD50LPW175 50" HDTV
DLP TV starts to loose picture after 1 - 1/2 hours of use
This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. see which inputs have the problem to narrow it down. if only some inputs, suspect analog board. if everything flickers(all inputs and menu), suspect the dmd or engine. you can see the lamp shine out the back. if the lamp is flickering, suspect lamp or ballast.
Nov 22, 2008 | Samsung HLN5065W 50" Rear Projection...
Noise from Samsung rear projection DLP HD TV.
this noise is an indication of a bad color wheel. aa dlp uses a mechanical motor to spin a coloered segment disk. this turn the white light of the lamp into your colors of pictures. Now anything that moves will eventally break. the flickering is also an indication of a color wheel going bad. eventally this will cause the set to shut down. Color wheels can be replaced. i dont know your model so i am not sure of the exact replacement procedure. at my shop we charge average 250 for such a repair
Oct 31, 2008 | Samsung HLN5065W 50" Rear Projection...
Missing Color.
the color wheel may spin but if you hear noise when it spins it's bad. the jumper is used when replacing one type of color wheel for a nother type. so donot remove jumper unless you've replaced the color wheel and the picture is bad. if the color wheel is good replace the DMD board. if the DMD is not available replace the optical engine.
Jan 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
