Question about Maytag 24 in. MDBH965AW Built-in Dishwasher
Maytag MDBH965AWQ I have a Maytag dishwasher model number MDBH965AWQ. A few weeks ago the clean and sanitized lights would not go off after the door had been left open for over 30 seconds. Then last week, the diswasher would shut off in mid cycle and all lights would turn off with water still in the dishwasher. Today, I noticed that I am able to open the dishwasher door while the dishwasher is running and it will continue to run like the door was never opened. Now it is starting to trip the breaker on the outlet. What could be causing the problem and I would I fix it?
  • bdray16 Jun 20, 2009
    Thank you for your advice Masteria but I do not have problems with the door falling down. The problem I have is with the dishwasher shutting off by itself and now power surging. Here is a summary of the problems in order of what I have experienced over the past couple of weeks:
    1. Clean and Sanitized light stays on after door has been opened for more than 30 secs.
    2. Able to open the door and the dishwasher continues to run.
    3. Causing a power surge that trips the breaker in the outlet.
  • 15,935 Answers
2 items in need of testing are the door switch - and the main controller board/timer unit.
CLICK HERE for all the blowout diagrams of your dishwasher.
the entire handle assembly (--with switches--) is HERE
the switches alone are HERE
the Control Board is HERE
Test/replace the door switches first - as they are the cheapest, and most likely to fail. They must be removed and checked for continuity - individually.
All you can do with the control panel is verify power to and from the switch with a Digital Multimeter.
If there is no power TO the switch - the board is faulty.
It is my opinion since there is more than one problem - in your case the control board is the culprit.
If you need additional questions answered please use the "Continue With This Expert" option so we are connected in the future.
Thanks!!
:D
Posted on Jun 20, 2009
  • 355 Answers
The dishwasher doors falls down: You may have had a door spring break. There several different door springs, but most, if not all dishwashers have 2 door springs. You will need to remove the lower access panels to get at the springs. They are fairly easy to get at and replace :-) This is a collection of some common springs used today, link is here.
Posted on Jun 19, 2009
Clean sanitized washing lights flashing
Hello Brian, thank you for your post!
I understand Clean, Sanitized and Washing feature lights are flashing. Let's try resetting your dishwasher. This can be done by either unplugging or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your dishwasher on. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, door latch assembly, or control board. At this point, I would personally contact a professional to accurately diagnose your dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Best of luck, Chris!
Dec 23, 2013 | Frigidaire 24 in. PLD2850 Built-in...
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
Why are lights flashing on my dishwasher's control panel?
There is a button configuration that you can press to make the unit reset on some you would close the door and push normal wash heated dry then normal wash then heated dry on others it would the econo wash button then heated dry then the econo/ heated dry this pattern starts the unit and then puts it into the drain cycle and resets the control which allows you to start washing again. If you can name off all the buttons you have I can tell you exactly which ones to perform this reset in the unit. I await your reply
Rick
p.s this also happens on whirlpool models as well right after the warranty runs out so you end up paying the high service charge for a tech to walk in you door push a few buttons then collect a fee over 169.00 which is ridiculous.
Nov 17, 2011 | Maytag Dishwashers
Brand new Matytag MDB7749AWB Dishwasher does not work correctly. As soon as the power was turned on, all three cycle indicator lights ('Wash', 'Dry', and 'Clean') came on and always...
Try putting the unit into a test mode. This my clear your issues otherwise call for service.
One of two ways to do this.
In standby (no lights) Press the combination of buttons:
hi temp wash > sanitize > hi temp wash > sanitize > hi temp wash
All lights will come on and the washer will run a test cycle anywhere from 5 to 10 minutes.
If that button comb doesn't work use:
heated dry > sanitize > heated dry > sanitize > heated dry
May 27, 2011 | Maytag Dishwasher
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
My dishwasher (Maytag MDBH965AWQ quiet series 300 was purchased in May 2006 (making it just a little over 4 years old). The handle broke on it initially and now the control panel has gone out including...
Well Kathy, you may be in luck. There has been a safety recall on your model of dishwasher and Maytag will give you a considerable allowance to replace with another Maytag. You may contact them at 1-800-544-5513 with your model and serial number and they will give you instructions on how to obtain your new dishwasher at a deeply discounted rate and all the details.
Sep 11, 2010 | Maytag Dishwashers
Some of the buttons on the touchpad will not work. What can we do? Normal wash and Insta wash and Auto wash will not light up, nor does the time display for these two options go on. Heated Dry and Sanitize...
Unfortunately the only way to fix that problem is to replace the console which includes the button pad. I can look up the part number and approx cost of the part if you confirm your model number from the tag just inside the door and the color of the dishwasher.
Apr 25, 2010 | Maytag 24 in. MDB8751A Jetclean II...
Maytag Jet Clean leaking through right side of door during rinse
It is important to examine the leak to see where it probably originates.
If the water is leaking from the right hand side of the door on your dishwasher, it is time to replace the gasket that seals the door when the door is latched.
Aug 10, 2009 | Dishwashers
Kenmore Dishwasher Not Sanitizing
You don't need an additive.
The sanitized LED itself is probably out.
It will not light up if the sensor doesn't sense that the water has reached 155 F. If the dishes are getting clean, I assume the heater is working properly. You could have a failed sensor, but you would usually notice longer than normal wash times and the dishwasher getting hotter than usual.
Alternately press heat dry and hi temp scrub 4 times. This puts washer into diagnostic mode. The first thing that happens is all the LED's light up. If it lights up then it is ok and the problem is somewhere else.
If these instructions don't apply to your machine, please post the complete model number from the decal just inside the front of the tub and I will look it up for you.
Nov 16, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Maytag Dishwasher
we have a model mdvtt53aww1 and you can push three buttons and will light up the hi temp wash, heated dry and sanitize is there a code make it start
Oct 01, 2007 | Dishwashers
Maytag 24 in. MDBH965AW Built-in Dishwasher Logo
258 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
