Question about Dewalt Saws
Dewalt reciprocating saw DSC381
I have a year old dewalt reciprocating saw DSC381, It has just stopped working when i pull the trigger nothing happens, and if i giggle the tool hard enough it starts working for a little bit or sometimes with very low speed, is there a way to fix this problem to get it running again?
5 Suggested Answers
  • 313 Answers
SOURCE: Dewalt DW303 reciprocating saw
go to www.dewaltservicenet.com look for the icon find it now.enter the model # of the tool & search
Posted on Sep 19, 2008
SOURCE: Reciprocating saw stops reciprocating
your missing a tooth on a large round gear in the gearbox.
when the gear on the engine rotates into the position where the little engine gear spins because there is no tooth to come into contact with the engine runs but the gearbox doesnt spin, hence no reciprocation, but engine runs.
if you bump the blade it will start going again, but when you cut it will stop offasionally in mid cut. you can repair this but stop using it the engine gear will be destroyed otherwise
I have a dewalt dw303 that you can use for parts, I need a new trigger or something the motor is dead and I found a new saw. go to craigslist.org, rochester ny tools section and look for dewalt dw303 that is my listing. for ten bucks ill sell you all the gears you need. i think it is close to the same model, i am sure it is the same gearbox.
try opening your gearbox, im positive that is what is wrong.
Posted on Apr 23, 2009
rowdy45176
  • 2176 Answers
SOURCE: reciprocating saw only works at certain angles
It sounds like the cord has a broken wire in it or there is a loose wire at the switch. Unplug tool and if you are comfortable in removing the handle halves look at the switch wiring and I pull gently on the wires from the cord to see if a can pull one out. Let me know if you still need assistance and I will go into more detail.
Posted on May 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: My Dewalt DW938 battery powered reciprocating saw is eratic as to the reciprocating motion. The motor always turns when the trigger is depressed but the reciprocating action either doesn't start o
sounds like you have a gear problem, I suggest going to dewaltservicenet.com and typing in yoru model number so you can download a schematic for this tool. you have a problem in the gearcase area.
Posted on Feb 09, 2012
Hi there, I am looking for the replacement switch, model # 152398-12, hard to find
Dewalt Trigger Switch 152398 12 ' eBay
www.ebay.com/...SWITCH-152398-12-/331707...
Translate this page eBayDEWALT TRIGGER SWITCH 152398-12 in Casa y jard?n, Herramientas, ... RidgidReplacement Pinion 680292003 for a R8442 Cordless Reciprocating Saw.
Dec 28, 2015 | Saws
Dewalt Model D304-04 reciprocating saw wont run. I plug it in, pull the trigger and it wont start. What am I doing wrong or what could the cause be?
Hi Fred:
Hmmmmm.
- Confirm there is power in the plug.
- use continuity meter to check that there is a complete circuit through the saw.
- broken connection in plug?
- broken wire between plug and switch?
- switch not functioning?
- switch set between forward and reverse?
- Speed control potentiometer contacts dirty?
- Bad brushes?
Aug 25, 2015 | Dewalt Saws
Why the DC385 does not start /
My guess would be either a failed switch or a failed (motor) brush, unless you've been using it REALLY hard and burned up the motor windings. You'd really have to work it HARD to do that, though.
Aug 04, 2014 | Dewalt Tools (DEWDC385K) 18V Cordless...
Feb 05, 2012 | Saws
I have a Dewalt DC385 Reciprocating saw, when I hold it with the blade down or level the saw will not work but when I have the blade pointed upwards it works fine. I don't think it is the trigger...
I would look at the battery contacts first for burnt/discolored contact, if so clean with something like a pencil eraser, look at the contacts on the tool also. If these are acceptable then I would think a loose wire inside the handle area is causing. Before disassembly hold tool level and GENTLY tap with a soft hammer to see if you can get it to work and that would be a first indication of a bad connection
May 23, 2011 | Dewalt Dc385 Reciprocating Saw 18v Tool...
Saw seems dead, after 8 - 12 trigger pulls the saws turns on (sometimes) but after you release trigger its dead again???
You should check the brushes and cord first but it sounds like your trigger is shot, not an uncommon failure for this tool. With the cord plugged in, hold the trigger on in one hand and bend the cord around in several placed, especially near the boot and push and pull it in the tool. If it comes on, replace the cord. If the it doesn't react to this, check the brushes. Without knowing which model you have, they should be at least 1/4" long, evenly worn and shiney, not burnt, where they touch the armature. If these check out you need a new switch.
Dec 23, 2010 | Dewalt 10.0 AMP Reciprocating Saw
My recip saw just quite working I was cutting and
The switch has gone bad and the contacts are gone...
you will need to replace the switch...
heatman101
Dec 04, 2009 | Dewalt Saws
Mar 18, 2009 | Dewalt Heavy Duty Reciprocating Saw Kit
Saws Logo
48 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
