Question about Pioneer VSX-D509S Receiver
My receined just says powering off
Received constantly says powering off
One of my customers has a CMD6 with SIR-CL3 Sirius receiver. When powered up the unit displays "SIRIUS NO TUNER" and then shuts off, powers itself up again, repeats display message then shuts...
I am having the exact same problem with my CMD6. The sirius worked fine with my CMD4, but has the same problem with constantly rebooting when I hook it up to the CMD6. Did you find a solution?
Feb 08, 2011 | Clarion CMD6
I want to switch the power on my car cd player away from the starter, so that i have to turn it on and off myself, rather than when i turn the key. how??
Surely you mean that your cd player is connected to the accessory power and not the starter. If you want your cd player to receive constant power then locate the accessory power wire of the cd player(the one that receives power when the key is on) and connect it to a FUSED constant power source(battery). Usually, if it's a three wire hookup it will be yellow, red and black. Yellow (constant power), red (switched power) and black is ground. If this is the hook up then the red needs constant power. If it's a two wire hook up, red (switched) and black(ground), then the red needs constant power.
Jan 14, 2011 | Car Audio & Video
My cdx won't store radio stations
you probably have the constant power and the accessory power reversed or your constant power has blown a fuse...
Apr 29, 2010 | Sony CDX-MP40 CD Player
I need wiring color coding 4 pioneer deh 2050mpg? i know red is constant power.
Not to question you about the red being constant power but I have a pioneer deh-1600 car stereo and red is hooked to electric terminal controlled by ignition switch (on/off) and if your unit has a yellow wire that goes to constant power. The only problem with hooking up the red wire to constant would be if you happened to accidentally leave your player on it could drain the battery. Hope this helped a little. Good luck.
Oct 10, 2009 | Pioneer DEH-P2000 CD Player
Which wire to connect to continuous power
yellow wire goes to constant 12 volt power (or battery+ terminal, but you should be able to find constant power in the car...), red to switched, black to ground.
Jan 18, 2009 | Car Audio & Video
Receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Jan 04, 2009 | Sony STR-DE635 Receiver
Constant hum
CHECK THE ALL THE CABLES (RCA) .
i think missing ground sheeld .
or smoothing capacitors are leak.or power output section faulty.
can you poen the cover and check circuit board get wet anyhow,
nuwan
Sep 23, 2008 | Sherwood RD-6500 Receiver
Dish VIP 622 constantly resetting
You have already completed all the main steps to try this on your own. Your receiver is going to need internal repair. You can use our premium service for step by step instruction or you can contact a local repair service by using our Repair Service search engine on this site.
Jun 28, 2008 | DISH Network ViP622 DVR DTV Receiver /...
Everything resets after power off
You should always wire constant power to the battery. This allows you to guarantee constant power. Don't trust anything else and you will always have success. TO THE BATTERY!!
Dec 27, 2007 | JVC KD-G430 CD Player
Fax machine
1-check the black spongy roller inside the machine, is it in place, does it look o.k.?
2- toner is bad replace
Dec 13, 2007 | Office Equipment & Supplies
Pioneer VSX-D509S Receiver Logo
48 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
