Question about Earthwise TC70001 - Corded Tiller/Cultivator, 8.5 Amp
Earthwise tiller tc70001 stops after 10 seconds
Stops working after 10 seconds of operation
How ican find a manual for earthwise cordless blower
[PDF]OPERATOR'S MANUAL
iteminfo.amleo.com/.../ewblower/CB20018%20CORDLESS%20LEAF%...Your cordless blower has been engineered and manufactured to our high ... and other !nfom1ation contained in this manual .... Earthwise m service center.
Nov 01, 2015 | Garden
The tiller starts and runs well for about 10 to 15 minutes but then will bog down and stop running . It will restart and run for about 30 seconds and then stop again. Any ideas about what is causing this,...
It sounds like a carburetor fuel issue. Which you could try attempting to adjust the carburetor (or have someone else do such) to see if that cures the problem.
May 16, 2014 | Honda 25cc 4-cycle Mini Tiller
Honda Tiller revs and works for 30 seconds and then shuts down.
Hello. you have some gunk in the carburator. Get a can of starter fluid or carburator cleaner aerosol and a helper. Remove the air filter and start it up. Spray a little starter fluid into the air cleaner to keep it running for three or four minutes and the problem should clear. If it does not clear the carburator will have to be disassembled, cleaned and rebuilt. j.
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
Mower started smoking, then stopped working.
Try to see if there is any oil in it. Or maybe your belt is clogged. A good cleaning and maybe a change of plug may help.
Mar 01, 2010 | Electric Earthwise Corded Lawn Mower...
It will start OK and run for a few seconds then I hear a click and it stops running.
Had a similar prob. Are you fIooding? I don't know how old your critter is but I replaced the diaphragms, a.k.a. fuel pump, in the carb. (About $10) Then screwed in the idle adjustments all the way-LIGHTLY-and backed them out 1 1/4 turns. Once running, adjusted to a smooth high and low idle and per instructions.
Jul 09, 2009 | Mantis 2-Cycle Tiller
Tiller starts then stalls
The air filter should be replaced. Also remove the old gas and put in new from the gas station. Finally, if you didn't change the spark plug from last seaon, do so as it is a small amount of cash for a lot of easy starts.
Apr 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Earthwise TC70001 - Corded Tiller/Cultivator, 8.5 Amp Logo
87 people viewed this question
Top Earthwise Garden Experts
Steve Sweetleaf
Steve Sweetleaf
 Larry
Larry
Call Bill
Call Bill
Are you an Earthwise Garden Expert? Answer questions, earn points and help others
