Question about Bionaire Air Purifiers
How long do I keep the device on - Bionaire Air Purifiers
Is this invrioionizer safe for people with heart or lung disease
Those devices use a process call IONIZATION to clean the air. What this does is make high voltage that jumps out into the air and attaches to particles in the air. Those particles are now attracted to anything with an opposite charge. In some machines there is a plate that has the opposite charge and a fan that pulls the air into the machine. When particles that are charged come into the machine, they are drawn to that plate and stick. The plate gets dirty pretty fast and has to be cleaned. The problem comes when the ionizer begins to spark. This creates ozone and ozone is harmful to people and animals, rubber and many other things. I looked up the name of the machine that you listed and the closest I can find is a really old reference to a radio shack device. the Environizer™ (630-0612/630-0613) This device was made just after regulation by the federal government that says 50 parts per billion is the limit so that device SHOULD be ok. However it has to be maintained and cared for. There is a great article here:http://www.allergyclean.com/problems-with-ozone-generators-and-ionizers-that-produce-ozone/
Just keep in mind the difference between ozone generators and air ionizers, they are not the same thing. If you need more info let me know.
Mar 11, 2016 | Air Air Purifiers
Plug the 120v device into 240v outlet
Your air purifier most likely is fried.
Feb 26, 2018 | Honeywell Air Purifiers
Device appears to have no power. Power cord looks good, it was working the day before then suddenly stopped working... no lights indication of any power making it to the device.
This unit will not operate if it is plugged into a power strip - it must be plugged directly into the wall outlet. An extension cord may be used.
Aug 16, 2011 | Honeywell (18155) Air Purifier
I lost neutral on the electrical service and my cleaner no longer works, i changed the fuse that had blown, but when i turned the filter on it simply blew the new fuse
Blowing a new fuse would indicate that there is some component of the machine which was damaged. The fuse is a safety device which keeps electricity from flowing through defective wiring.
You can visually inspect the machine to see if there are any wires, connections, or components that appear to be damaged, burned, loose, or broken. The plates need to be perfect, without cracks, burned spots, loose mucilage, broken screens, etc. The contact fingers should be screwed firmly in place, and they should press firmly against the screen part of the plate.
If you can detect and then repair any of the above defects, and if the machine still blows the fuse, you can assume that the problem is deeper in the machine and it needs professional help! Unfortunately, Vollara (formerly EcoQuest) no longer makes or repairs the Flair. You can contact Vollara customer service 800-989-2299 to locate a dealer in your area; they may have another machine or know where you could get one. They may also know of someone who could repair it for you.
Jan 12, 2011 | Ecoquest Flair Air Purifier
Stopped working
The problem most of you are describing is with the "TOUCH SCREEN" device. If it is cracked or broken the system detects a fault and goes into a default mode. I suspect that Brookstone is aware of this problem but did nothing to warn its customers. Nor did the company provide a source of repair parts. I have a model 506840 also and after cleaning it , the problem appeared. The unit was never dropped or mistreated but it is now inoperable. The best approach is to check the screen for cracks. Then check to make sure it is plugged in properly. I am trying to get some parts from Brookstone myself. But, so far no luck.
Sep 10, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Flair system
Fow owners of all these type devices read my profile, in this current economic times, we are taking in home appliances for estimate of repair, see my profile at allexperts.com
We cannot repair a device that cost $29.00 new for five bucks but if you have a device that is worth something and the only option is to pitch it write me and we will see if we can help wbwill@sbcglobal.net
we will estimate and report back for a proceed
Jul 15, 2008 | Ecoquest Flair Air Purifier
Oreck XL® Professional
clean your cell. Allso check for broken or loose tungsten wires in cell.
Dec 03, 2007 | Oreck (AIRCOM1WOI) Air Purifier
How much ozone does this produce.
The Food and Drug Administration requires the ozone that is given off by medical devices that are used indoors to be no more than 0.05 ppm. If you have a manual, does it specify the amount of ozone given off? I'd be interested in the figure.
Sep 23, 2007 | Zelco (1410580) Air Purifier
Air Purifiers Logo
Top Bionaire Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Tim Whalen
Are you a Bionaire Air Purifier Expert? Answer questions, earn points and help others
