UNIT RUNS ALL DAY AND NIGHT WILL NOT COOL UNDER 78 DEGREES-ALSO WILL NOT EVEN HOLD AT 78 DEGREES. HAD THIS UNIT SERVICED OCT 29, 08. IT IS STILL UNDER WARRANTY-BUT WAS CHARGED 700.00. CAN'T AFFORD TO GO THROUGH THIS AGAIN.
  • 146 Answers
It sounds like thermostat which tell unit to turnoff
and set the temp. you can test them with hair dyer buy putting it on heat see what dose then cool. The display should show the temp. if so then it should shut off or turn on is. If not could be a bad thermostat. Or is the thermostat in a hot spot in the house is should be near the return. Hope this helps. Yes I do for living Paul
Posted on Jun 19, 2009
I am working on a M # GPG13420901AB. This is a 3.5 ton package unit that replaced a 3 ton package unit on 1700sq/ft single level home. Old unit was working fine but was replaced when the home was...
It sounds like you are low on charge. I think you have a thermostatic expansion valve and you need to check the subcooling, you should have 12 to 15 degrees at 95. At 95 degrees your head should be about 280# for a 12 or 13 SEER unit or higher depending on the effeciency. At 78 to 80 degrees indoor depending on the humidity, that is normal. The valve will open to try to fully feed your indoor coil and it sounds like your head pressure is to low to force enough refrigerant thru the coil.
Aug 16, 2010 | Goodman Heating & Cooling
Day / Night HVAC is running cool air BUT the furnace is running 2
Strange. Does the thermostat control both the air conditioning units and the furnace. If not make sure the furnace thermostat is turned down to below 65 degrees.
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
AC unit is running, but the house doesn't get cooler.
a/c is either on or off,there no in between.check air filters make sure they are clean.also keep in mind a/c will only bring temp down about 15 degrees from outdoor temp
Jun 23, 2009 | Honeywell Electronic Programmable...
Cools only at night
Possibly low on gas . Take Thermometer and check the outgoing air. Should be close to 45 degrees If not low on gas. Rusty
May 06, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
What tempratues should be set on a honywell 4 cycle thermost during the summer months
As a general rule set your t.sat 20 degrees below outside temp. Leave at this setting 30-45 minutes. Move down until comfortable no lower than 10 degrees below outside for 30-45 minutes. Unit should cycle normally. If it runs continuously then raise the t.stat 3 or 4 degrees up. The national average is 75-78. I usually keep mine set at 80 during the day here in Georgia and 74-78 at night...
Jul 03, 2008 | Honeywell Heating & Cooling
Cooling Problems
Your filter is clogged. Not the one at the bottom of the unit.The one above the unit. It is like a raditor coils, kind of a bear to get to. We have cats and dogs the filter gets most of the hair but not all.Usualy about 6 bolts to take out.The proublem will be at the bottom of the top filter.
May 09, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
248 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
