Question about Epson Office Equipment & Supplies
Epson workforce 610 software won't let me select "film" in professional mode
Thee is an option for "film" but it is grayed-out.
SOURCE: Epson 4490: where'd my "film" option go?
I had this problem, turned out the cable between the lid and the main chassis of the scanner had pulled out slightly. Plug it in and problem solved.
Posted on Jun 02, 2009
  • 35 Answers
SOURCE: Can't use the ''Film selection on epson V700
Make sure the transparency light cable that comes from the lid is plugged in to the back of the scanner. If the cable is unplugged for any reason, the transparency/film options will not be available.
Posted on Jun 14, 2009
SmartAviator
  • 449 Answers
SOURCE: negative images
Check the settings and try to update the software/drivers if available from manufecturer's website. (ehteshamhusain@gmail.com)
Posted on Jul 19, 2009
  • 8 Answers
SOURCE: negative or positive option is not available on
I just had the same problem, turned out my FAU cable was not properly connected. Ensure that the cable is all the way inserted at the back of your printer, and connect the device to your computer. I hope this will work for you too:)
Posted on Jul 25, 2009
yammy_alf
  • 666 Answers
SOURCE: Problem scanning film with EPSON V300
check if upper cover remove for film scanning, bulb must be visible upon scanning in negative or positive film.
Posted on Mar 23, 2010
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
Epson workforce 610 printing improperly
have the printer being discussed in this thread.... the Epson WorkForce 610. I just encountered the same issue, many lines were missing from the page that I wanted to print. Ink levels were fine, but every time I try to print the same thing, the same lines were missing. I read through the solutions mentioned above and I decided to see what the printer had in its maintenance toolbox on the printer itself.
Here's a solution that worked for me!
1. Go to "Setup"
2. Under Setup, select "Maintenance"
3. Select "Head Cleaning"
The printer does the head cleaning automatically. Print another page, all of the lines should show up!
Simple, no need to buy another printer or clean the ribbon...
May 01, 2012 | Epson WorkForce 600 All-In-One InkJet...
My compter got a virus and while down ,it lost capability to connect to my wireless workforce 610, and I lost the cd software.can I install it somehow ,thanks
Hi maureenengel,
Dealing with the aftermath of a virus can be really frustrating. Fortunately, the software for your Epson Workforce 610 can be downloaded from Epson's website. The download page for this particular device is http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=130786&prodoid=63084540&infoType=Downloads&platform=All.
You'll want to download the "Drivers and Utilities Combo Package." Double-click the downloaded file, and then follow the on-screen instructions to reinstall the printer software.
May 26, 2011 | Computers & Internet
How do I set my Epson WorkForce 610 to print via bluetooth from my droid 2?
(1) i hope you fully installed the network/wireless device software on the host computer and then followed all the on screen instructions.
(2) during the installation program attempts to find the printer.in the mean time turn on your Bluetooth on your phone and attempt to search the printer.
(3) make sure the entered the correct network name and security passkey.
May 13, 2011 | Epson Workforce 610 All-In-One InkJet...
Have an epson workforce 610 series.... the machine will not turn off using the power button.. weird.. how do you get the thing to turn off w/o unplugging it... tnx.. cecile
When you push the power button does a warning show on the printer's screen about "Saved fax data/ received will be deleted?" If it does, select the YES option and the OK button.
Hope this is your solution
Aug 21, 2010 | Epson WorkForce 600 All-In-One InkJet...
Keeps saying paper jamed when I try to print
On the Epson website it is confirmed that the Epson WorkForce 610 will not recognize transparency media. It is just the way the printer works; if it can see through the media, it doesn't think it's there.
However.....you can tape a sheet of white paper to the non-printable side of the transparency, and it prints just fine. I put two strips of scotch tape on either side, top and bottom. Works great. It's kind of a hassle, but better than not being able to print transparencies at all!
Jul 22, 2010 | Epson Workforce 610 All-In-One InkJet...
Epson v500 not able to scan negatives! When I open uop the software, they don't even give me the option to scan negatives, just photos!
You probably need to reset (not reload) the scanner software. Start the Epson scan software. Select professional mode from the pull down menu (it lets you choose between auto, home and professional.) On the next screen select at the very bottom select configuration. The next screen should have 4 tabs, select other. The at the bottom (I think) select restore to factory defaults. This will reset your software, now you can use auto mode if you want it to make all your selections or home if you want some control or professional if you want to control everything. Don't forget to use your film holder that came with the unit and remove the white cover that is locked underneath the lid that covers the film illumination bulb.
Jul 07, 2009 | Epson Perfection V500 Flatbed Scanner
Film option is ghosted
try to reseat (unplug and replug the TPU cable at the back of scanner, and open epson scan go to professional mode and click on configuration button, go to OTHER tab and press reset all then restart computer and try if film is an option to select.
Jan 15, 2007 | Epson Perfection 4990 Flatbed Scanner
26 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
